What happens when you are distracted
JumboJet
Before:
After (when you have a friend that can "Buff that right out"!๐Ÿ˜ž
39 REPLIES 39
Specularius
Jumbo, was that a Solitude that was dropped?
2015 F-350 DRW 6.7 Scorpion Diesel Reese Ford Hitch
2014 Grand Design Momentum 355TH
cummins2014
Boy !! I could hear all you B&W cheerleaders holding your breath, but no worries all is well in the world of the fan club. :B
Lantley
jjj wrote:
That is why I bought a bed saver for my curt hitch. Not because of possible failure , not because of getting older and forgetting, is because one distraction can cause a whole lot of damage. I glad I spent 200.00 for my peace of mind. It happened to me many years ago but is not going to happen to me again.
I also have a Blue Ox bedsaver. I consider it cheap insurance.
Just like insurance. you hope you never need to use it. But when stuff happens you are glad you have it.
No one plans to drop their 5'er or have a need to use insurance but as we know stuff happens.
jjj
2002 F-350 Crew-Cab Dually
V-10-4.30 gears Mag-Hytec diff.cover
w/Amsoil-6.0 trans cooler Curt Q5 20K hitch & bedsaver
2005 Keystone Challenger 34TBH-Fifth Airbourn
RustyJC
fj12ryder wrote:
Rusty, AFAIC if you have the handle locked open every time, at some point you'll will forget to remove the pin and the above will happen when hitching up. KISS. We'll just have to agree to disagree on this.
I only lock the handle open to unhitch, never to hitch. When hitching, I watch for the handle to move to the closed position to ensure that the kingpin is fully engaged with the jaws and then pin it closed and hook up the breakaway cable when I get out of the truck.
Rusty
2014.5 DRV Mobile Suites 38RSSA #6972
2016 Ram 3500 Dually Longhorn Crew Cab Long Bed, 4x4, 385/900 Cummins, Aisin AS69RC, 4.10, 39K+ GCWR, 30K+ trailer tow rating, 14K GVWR
B&W RVK3600
fj12ryder
Yep, I simply hadn't considered that it was an unhitching problem. And one that I have done before. No damage was done but it sure ticked me off. Distracted hitching or unhitching is a real recipe for disaster, or at least disgust. ๐Ÿ™‚
Howard and Peggy
"Don't Panic"
laknox
RustyJC wrote:
fj12ryder wrote:
But if you'll notice: it looks like the hitch arm is pinned open. Doing that almost guarantees that you'll drop the 5th wheel at some point.
I believe we've had this conversation before. B&W's INSTRUCTIONS specifically state to pin the handle in the open position when unhitching:
STEP 7: UNATTACHING TRAILER
Lower landing gear and block the trailer wheels. Raise the trailer until the tongue weight is removed from the truck. Then, unpin the Companion RV handle and rotate to the open position to unlatch the jaws. If the jaws do not open, readjusting the landing gear may relieve pressure and allow them to open. Use the safety pin to lock the handle in the open position and when you are sure that the landing gear will support the trailer, move the truck forward to release the jaws from the kingpin. The jaws will always open when the pressure of the trailer is taken off the RV Companion as the truck pulls away.
I've followed this procedure since installing my first B&W Companion in 2001 and haven't dropped a trailer yet. If someone chooses to do it differently, that's fine, but don't crucify the OP for unhitching in accordance with B&W's procedures insofar as pinning the handle open is concerned. He just missed the little landing gear thingy! :S
Rusty
Rusty, I think we all =ass=umed that this was a hitching accident, not unhitching. We now have the full story from the OP.
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
laknox
JumboJet wrote:
laknox wrote:
newman fulltimer wrote:
What did you do just not close the hitch?
I'd like to know, too. That's a B&W Companion, and you almost have to purposely screw something up to do this.
Lyle
The tall looking fellow in the 2nd picture is the owner of the truck. I am the repairman.
He stepped out of his truck and was distracted for a few minutes by another camper. He didn't follow his normal routine and unlatched the B&W before dropping the legs. The camper rolled backwards off the hitch. A pin catcher would have saved the damage.
Next: Repair the damage to the underside of the RV overhang. Will be using bright aluminum tread plate for the repair.
That's why =my= first step is chocking the wheels before anything else. Nice job, BTW. Got pics of the FW, before and after?
Lyle
newman_fulltime
Lyle
Next: Repair the damage to the underside of the RV overhang. NiceWill be using bright aluminum tread plates for the repair.
nice straightening job just a slight ripple under the cap
rwjejits
Lyle
You sure got a durn good buffing machine...
2004 Ford F250 6.0
OEM TTYs Still Tight
210+ and Pulls Great
Original Owner- Lawrence Marshall Ford - Hempsted, Tx. (Closed 2009)
SCT, SG2, Deletes, Pyro, Free Flowing Exhaust, Timbrens, ELC & Filter
2011 Keystone Laredo 245RL
ReneeG
blofgren wrote:
It certainly doesn't take much of a brain fart to cause a real problem. One time I couldn't figure out why my hitch was not latching; that is until I noticed that I still had the handle locked in the open position!!:S
Same here, that's when the questioning DW mode kicks in and this is usually the only time DH appreciates it.
2011 Bighorn 3055RL, 2011 F350 DRW 6.7L 4x4 Diesel Lariat and Hensley TrailerSaver BD3, 1992 Jeep ZJ and 1978 Coleman Concord Pop-Up for remote camping
Dave & Renee plus (Champ, Molly, Paris, Missy, and Maggie in spirit), Mica, Mabel, and Melton
JumboJet
Lyle
ReneeG
TomHaycraft wrote:
That could have so easily been me last weekend!
New (to me!) truck with a long bed. I pinned the Reese Sidewinder required for my prior SWB truck (and removed the wedge) and tried to use a lube plate. Seemed to hitch fine, jaws closed, button on front of Reese R16 hitch pushed out, maybe not quite as far as before, hitch handle swung (mostly) into the lock position. Two red flags I didn't fully investigate.
Pull test was fine. I got it out from under the covered parking and on to level ground. Stopping to check level and give it another look-over. This time I saw that the arm of this hitch wasn't all the way into the locked position. Feeling under the hitch head, I found how little was caught and up in the correct position.
The thickness of the lube plate caused the king pin to ride a bit high. I unhitched, remomved lube plate, got out my grease, hitched back up.
I was lucky.
Last time we hitched up we too had problem with the lube plate preventing a complete lock on the hitch head. Since we were only going a short distance, we removed the lube plate, hitched, and locked and headed home.
blofgren
2013 Ram 3500 Megacab DRW Laramie 4x4, 6.7L Cummins, G56, 3.73, Maximum Steel, black lthr, B&W RVK3670 hitch, Retrax, Linex, and a bunch of options incl. cargo camera
2008 Corsair Excella Platinum 34.5 CKTS fifth wheel with winter package & disc brakes
RustyJC
Rusty
B&W RVK3600
