Sep-12-2007 09:05 PM
May-02-2012 05:50 AM
May-02-2012 05:29 AM
phalynx wrote:
Just found out mine, trying to find where the weight is.....
TV 2007 Chevy CC D/A 4wd Dually with hitch, full of fuel, toolbox, 2 adults, 2 children, and dog. 8240lbs
5th Wheel -2007 KZ Sportsmen Sportster 37KGX3 - sticker weight dry 11,556. Sticker GVWR is 16,940. Actual scaled weight with all our clothes, food, etc and a golf cart, DRY!, 19,120. Sticker hitch weight 2940, actual 3520. I don't see a problem here. Looks normal. However the total weight on the axles is 15,600... that's 1,600 over the axle rating and 600 over the tire rating. I am at a loss. I hope it is scale error. I will be reweighing this weekend.
Total GCWR 27,220!!! Truck rated at 23,500. I have no idea where the weight is. I can only hope that the scale was wrong. We did not load 7500 lbs of gear in here. Not to mention the fact that all tanks were empty and I have a 110 gallon fresh tank.....
Apr-25-2012 03:47 PM
avvidclif1 wrote:Kenny3p0 wrote:
Here is my question, How are you determining your pin weight?
My reading was axel 1 4520 axel2 5940 axel 3 10520 gross 20980
05 ram 2500 drw 3.73 auto gcwr 21,000
09 keystone cougar 316qbs
You have to drive off the scale, go to somewhere on the lot and unhook. Then go back across the scale and ask for a re-weigh, doesn't cost anything on a CAT scale. Then compare the numbers on the truck axles. The differences are the pin weight. If the front axle drops 500 lbs and the rear 2000 then the pin weight is 2500. The trailer weight won't change if it's level on the truck. It don't know if the pin box is on the truck or it's on the front legs.
Apr-23-2012 06:52 AM
Apr-23-2012 06:10 AM
Apr-22-2012 07:15 PM
Apr-21-2012 06:23 PM
Apr-20-2012 04:04 PM
Apr-20-2012 02:57 PM
Apr-18-2012 12:04 PM
livinglifegnd wrote:
hi guys am in the process of buying a 2008 Montana Mountaineer 345DBQ total dry weight is 11045 and payload is another 3265 hitch weight is 2310 according to specs wondering truck size I would need to purchase will be used why I am asking
Apr-18-2012 05:05 AM
Apr-12-2012 12:39 PM
Apr-12-2012 09:50 AM
Apr-11-2012 01:17 PM
Apr-10-2012 07:54 AM
pritch272 wrote:
TV - 2000 Ford F250 SD Super Cab 7.3 PSD, real scaled weight with full fuel, hitch, DH-DW and misc. gear = 7,640lbs. TV GVWR is 8,800lbs
5ver – 2007 Keystone Laredo 29RL 32ft 9,160lbs loaded GVW. GVWR is 11,000lbs
Normal running TV & FW GCW weight= 16,800lbs, TV GCWR is 20,000lbs
Real Wet Pin Weight=1,820lbs
