Sep-12-2007 09:05 PM
Dec-16-2010 02:31 PM
Dec-16-2010 10:40 AM
Dec-04-2010 02:20 PM
sirdrakejr wrote:If I understand all this right, we now compare his scale gross combined trailer weight actual of 11,080 to his 12,850 tow weight rating (presumably his tow vehicle's spec) and find that he is actually 1,770 lbs UNDERweight there and comparing his scale gross combined trailer & truck weight actual of 18,880 lbs to his 20,000 GCWR (again per TV spec) and find that he is 1,120 lbs UNDERweight overall? Which would mean that he is far from danger?
The weights you show say the truck weighs 9900# with the trailer on. The truck weight as 7800# subtracted from the 9900# weight shows the pin weight is 2100#. The total trailer weight is the pin PLUS the trailer axle of 8980# which = 11,080#. The 18,880# combined weight is the 7800# truck plus the trailer weight of 11,080# which is exactly right. It seems that you have matched trhe truck and trailer perfectly. I am assuming that the truck it a 1T truck, DRW or SRW?
Frank
Dec-04-2010 02:12 PM
Dec-04-2010 01:36 PM
partsman01 wrote:
Found this label after looking through the cupboards.
So if I understand this right, and I take off the weight of what they call the fresh water, which is the hot water tank and the fresh water tank I come up with 879Kg/1933.8Lbs for what I can put in as far as personal effects/cargo.
Am I close?
Plus if I take off these figures I should come up with my dry weight.
Which would be 3657Kg/8046lbs?
Dec-04-2010 01:19 PM
gotoloco wrote:
Can we really trust the manufacture and the weights, our Silverback has 9052 stamped on it as uvw, the options that we have are two recliner chairs and table and four chairs. Now the weight is it before they add the appliances, couch, bed and such?? This our fifth wheel and before have always had small ones so not as concerned with the actual weight of the trailer. How does one find out that information?? Also there are so many different ideas regarding weight that how does one really know??
Dec-04-2010 01:10 PM
sirdrakejr wrote:Thank You Frank! Now is there something visible from the road that will indicate to me it is a public scale before I get into the exit line? I suppose that probably varies from state to state...I'll keep my eyes open for a scale with a short waiting line.
There are truck stops that have scales for public use. Usually it will cost about $8 or so for the first weight on the empty truck. Then they allow you a return weigh with a trailer in less than 24 hours. Ask about that. That will give you all the weights you need to figure the numbers you need.
Frank
Dec-04-2010 10:30 AM
Dec-03-2010 08:30 PM
Dec-03-2010 06:56 PM
Dec-03-2010 01:58 PM
sirdrakejr wrote:
In the newer models of trailers there is supposed to be a GVW tag/label in one of the kitchen cabinets that will show all the weights and also the options for that trailer. The tag on the outside SHOULD have the empty weight including the full propane tanks. You can then figure the difference that you can add to the trailer and be under the GVW AND the GAWR. The best way to know is first weight the tow vehicle alone with full fuel and passengers. Then weigh the combo and figure the actual pin weight and the trailer weight.
Frank
Dec-03-2010 01:50 PM
Dec-03-2010 01:36 PM
Dec-03-2010 10:10 AM
Dec-03-2010 09:39 AM
