Sep-12-2007 09:05 PM
Oct-16-2010 10:01 AM
Oct-14-2010 01:47 PM
Oct-11-2010 04:49 AM
Oct-10-2010 06:14 PM
TimnJo wrote:
TV - 2007.5 Chevy Silverado CC/SB D/A LTZ
Fiver - 2003 Glendale Titanium 32E37, empty fresh, 1/3 full black and 2/3 full grey:
Steer axle 4620 Lbs
Drive axle 5220 Lbs
Trailer axle 8620 Lbs
Gross weight 18460 Lbs
Assuming truck weight of 7750 Lbs trailer = 10710 Lbs
Specs for truck from GM:
GAWR(F) 4860 - Under by 240
GAWR(R) 6884 - Under by 1664
10584 -
GVWR 9200 - Over by 640
GCWR 22000 - Under by 3540
Oct-02-2010 07:57 PM
Sep-28-2010 08:11 AM
Sep-24-2010 10:36 PM
Sep-24-2010 06:06 PM
Sep-16-2010 06:24 AM
Sep-10-2010 08:30 AM
Tireman9 wrote:
Some data that is very obvious by its omission is the real loads on each tire.
I see lots of posts with the numbers for all axles ( 2 or 3 ) combined but almos no data on individual axle loads.
I have read elseware of 2 axle TT being close to 46/54 than 50/50 and of a three axle unit being 30/32/37%
The other part of the important equation is actual side to side variation with few units at 50/50 of that axle's load and some axles being at 45/55%
So unless you have weighed your unit with its full load (food, clothes, water, propane and other "stuff") you are only guessing at how much load you are actually asking your tires to carry.
Even at max sidewall pressure you may be operating overloaded.
All the above also assumes the axles are all in align and none are bent which of course introduces additional dynamic loading.
So as the title of this tread asks... "What is your Real Weights?"
Sep-10-2010 07:23 AM
Sep-02-2010 07:01 PM
Aug-29-2010 09:00 PM
transamz9 wrote:
I here you guys talking about the GCVWR.Where are you finding this info on the truck? All my Dodge 2500 and Ford F350 has is
FAWR
RAWR
GVWR
Aug-29-2010 07:51 AM
Aug-28-2010 02:37 PM
