Sep-12-2007 09:05 PM
Aug-28-2010 10:44 AM
Aug-27-2010 09:22 PM
lots2seeinmyrv wrote:
Hope this isn't a dumb question...but has anyone...or does someone know how to create an Excel Spreadsheet that we can access where we can just plug all the numbers in for the trailer and the truck and then get the results calculated to see if our rigs are overloaded or not? And it calculates the pin weight?
Seems like a lot of us are confused on what our tow vehicles can handle, me included.
Aug-27-2010 05:39 PM
dieseldad55 wrote:
I am new to the forum. We've been RV'ers for several years, and have had our 5er since late '05. Now that tires are blowing out, cracking, etc., I'm finding more and more info on how important weighing your rig is, especially when looking to purchase new tires.
However, I live Sacramento, Ca.,the most ignorant and least informed community when it comes to RV's. I have visited 2 of the largest and oldest RV dealers in this area, and found that no one has a clue as to where to take a fifth wheel trailer & truck to weigh. Also, to find a tire company that can actually help you with tire requirements in relation to trailer weight is near impossible.
So, does anybody know for sure, (not looking for maybe's) where I can get my rig weighed???
Aug-27-2010 10:35 AM
Aug-27-2010 10:11 AM
Aug-21-2010 03:20 PM
Aug-18-2010 11:57 PM
Aug-18-2010 10:33 PM
Aug-17-2010 06:13 PM
Aug-16-2010 06:19 PM
Aug-11-2010 09:01 PM
Aug-11-2010 06:56 PM
ramcneal wrote:
Look at http://www.catscale.com and search for San Diego. Here's one that I found.
HWY 905 & Piper Ranch Road
Otay Mesa, CA 92154
There are probably other scales around, but you definitely want a certified scale. The CAT scale that I use has several large pads which make it easy to place each axle on a different pad. All except for the trailer axles since they are so close together. Not having separate values for the two or three trailer axles doesn't seem to be an issue since you just take the trailer weight and divide it by two or three (# of axles) and you know how much weight the trailer axles are carrying.
snip....
What happens if you're over the GCWR. Good question. There are people on this forum and other forums that I read which will say you'll end up in purgatory if you go over any of the ratings. GVWR, GCWR, GAWR. At the same time there are folks at the opposite end who practically feel if your truck can move the weight you're fine. I'm in the middle, but lean towards the first group. The manufacturers have built these trucks with work loads in mind. To go over those numbers means you'll wear out parts of your truck at a faster rate than normal at a *minimum*. Going over the ratings could also be extremely unsafe for you and others around you. snip....
Does that help?
Aug-09-2010 04:39 PM
Aug-07-2010 05:19 PM
Aug-07-2010 03:29 PM
