Whats Your Real Weights? Truck and Trailer. The Real Deal
juzplanekrazy
I don’t know if it’s been done before or not but I was thinking about keeping a running list of real truck weights by year and type, and trailer weights by brand, size and what the total combined weight is of each guys rig. I was hoping the info would be a help for guys wondering about what the real weights are for a certain type of truck and to keep track of the more popular brand 5th wheel trailers. Another thing that will come out of it will be to see just how many guys really know what they are towing and if they know what their weight capacities are.
I’m sure it will take some time to compile a list and it will grow as guys add there info but I’m hoping it will help the newer guys in the long run to be directed back over to this thread in the future.
I’ll keep the TV lists to mainly the big 3 and from ¾ ton and up and I’ll try to keep the 5ers in a group by real GVW, length, and then manufacture. Any ideas are welcome as long as it makes things easier. And only real information can be given, so no guessing allowed. Only guys that have scaled there rigs or are totally certain of the weights.
Let’s see if I can keep the format real simple to type down and that will make it simpler for guys to refer back to and to keep track of.
Here we go……
TV - 2006 Dodge Mega Cab 3500 4x4, real scaled weight with full fuel, hitch, DH-DW and misc. gear = 7,500lbs. TV GVWR is 10,200lbs
5ver – KZ New Vision TH 38ft 14,500lbs loaded GVW. GVWR is 18,000lbs
Normal running TV & TH GCW weight= 22,500lbs, TV GCWR is 23,000lbs
Real Wet Pin Weight=2,950lbs
2021 Dodge Ram Longhorn 4x4 Dually
2019 KZ Durango Gold 371
B & W Companion 25K
859 REPLIES 859
Betsy_II
TV - 04.5 Ram, CTD, Auto, 3.73, SRW, Quad Cab, 4x4
- 16K Pullrite Superglide, line X, running boards
- roof rack on truck with 2 kayaks and 2 mountain bikes
- GVWR 9,900#, GCWR 21,000#
- actual weight 8,000# (back seat removed)
5er - 2007 Corsair Excella 26RKS
- GVWR 11,000#
- UVW 8,900# (actual)
- pin weight 1,700#
- axle weight 8,300#
- total weight 10,000#
GCW (TV + 5er) 18,000#
Wolley
1999 F250 4X4 CC LB 7860#
2001 Sea Breeze FW M2300 real weight 12,600(mostly empty and no water) sticker weight 10,800
2011 Cougar High Country 296BHS
1999 F250 4X4 PSD CC LB HandshakerFriendswood Weather
Greentow
Loaded, but with out the spouse on board, 21,400, scaled weight. 1950 on the pin. Truck is 7960 empty (OK loaded with me and my normal load, ready to roll).
Lee
2012 Cedar Creek 36 CKTS (loaded). Mrs Greentow & Missy & Maggie, Shih Tzu's with an attitude. USA(R). 30+ years in the Fire/EMS service, GS Life member.
TV is a 2012 RAM 5500 Quadcab with body by Eby (flatbed). Cummins 6.7 with 6 speed auto.
donhov
Heres mine
07 Dodge 2500 SRW short bed. Cat Scale
Truck fully loaded, wife 2 dogs, cat and full fuel. 7440#
Scale truck and 03 30RLBS Cedar Creek 19,600# 20000
The above weight was returning from Florida with about #500 extra lbs on board in the truck box including 3 tool boxes, television, microwave, suitcases, misc boxes of food and other junk that I normally do not carry, about 500 extra lbs. that was onboard when I had it weighed.
LOADED WEIGHTS Scale Rated
Front Axle 4400 5200
Rear axle 5920 6010
Trailer while attached to truck 9280
Truck alone Scale ticket
Front axle 4380 5200
Rear axle 3060 6010
Truck overall empty 7440 GVWR 9000
Truck only with camper attached 10300 GVWR 9000
Tire capacities are 3195 each 12780 total cap
Trailer GVWR 12190
Trailer tires 3042 each
Axe rating 5200
Over ratings 1300 Minus the 500 lbs extra about 800# over GVWR rating.
Air lifts add 1000# capacity so if I had air lifts I would be under ratings. Truck does not sag and rides, drives, stops well.
2003 Cedar Creek 30RLBS
2007 Dodge 5.9 Cummins Turbo Diesel 325hp/610Tq
4x4 3.73 axles short bed
Inferno Red W/Gold pinstripping
WAM
06 Dodge dually truck/camper with 2-car hauler:
Front axle, 4750 rated, 4100 measured
Rear axle, 9350 rated, 9680 measured
Trailer, 15,000 rated, 10,860 measured
Gross combined, 23,000 rated, 24,640 measured
Tire capacities,
front 6170
rear 11,600
trlr 15,240
2012 Ford F350/SD 4x4
Alpenlite 9.5 Cheyenne slide-in
spencefam
I've got an '05 Dodge 2500 CTD, QC, 4x4, short bed.
Weighed it today with a full tank o' gas and no pax, no cargo:
Steer axle: 4240 lb
Drive axle: 2780 lb
I pick up my first 5W next week. '08 Montana Mountaineer Bunk House!
webecreekin
The 2006 Chevrolet Silverado 3500 Crew Cab DRW Duramax/Allison has the following numbers:
--Gross vehicle weight rating: 11,400
--Max trailer weight (5th wheel): 16,400 lbs (2wd), 16,000 lbs (4x4)
--Gross combined weight rating: 23,500 lbs
Here are the nums on my truck and trailer combo as weighed on a CAT scale:
* front axle - 4240
* rear axle - 5900
* trailer axles - 9520
* total gross combined weight - 19660
* pin weight of trailer - 2380
* total weight of trailer - 11900
* total weight of truck (see above) - 7760
The trailer is a Cedar Creek 34RLBS. It only has two slides and therefore is probably one of the lighter ones.
My margins are:
--Gross vehicle weight rating minus actual vehicle weight equals excess load capacity:
---11,400 - 7760 = 3640 lbs.
--Excess load capacity minus actual load equals load carrying margin:
---3640 - 2380 = 1260 lbs.
--Max trailer weight (5th wheel) minus actual trailer weight equals trailer weight margin:
---16,400 - 11900 = 4500 lbs.
--Gross combined weight rating minus actual combined weight equals gross combined weight margin:
---23,500 -19660 = 3840lbs.
2015 Ford F-350 Lariat
2018 Cedar Creek 36 CK2
www.cedarcreekrvownersclub.com
Jim601
Going camping. Wife, collie, full fuel 27 gl tank, +-35 gallons fresh water.
TV: 2006 GMC Duramax/Allison, SWB, 4dr crew cab.
5er: 2005 Everest 29RL W/dual AC. Cert scales all weights actual.
Loaded:
Steer axle 4,240*
Drive axle 5,620*
5er axle 8,920
Gross Wt 5er/TV 18,840
Empty, 1/2 tank fuel (27gl tank), hitch
Steer axle 4,300
Drive axle 2,820
Gross weight TV 7,120
GCWR TV mfg 9,200/actual 9,860*
Drive axle mfg 6,084/actual 5,620
GCWR 5er/TV mfg 22,000/actual 18,840
*A little over on the TV GCWR, but, the match up handles like a dream. Handles 9% grades EZ EZ. Weight is light on all other.
nubeee1
CAT scales:
Steer Axle, 4600lb
Drive Axle, 7320lb
Trailer Axle, 11240lb
______________________
Gross Weight, 23,160lb
TV GVWR 13000lb
5th GVWR 16000lb
TV GCVWR 26000
Everything was loaded with our "stuff" No liquids in trailer.
If I did it correctly I think my pin weight is 1830lb
See sig for truck. Its was ordered from ford with Tow Package, Boss Command and beefed up rear end (F450) HOA thing.!!
Tom & Cindy
06 F350 PSD dually CC LB
20.5K Pullrite 5th Hitch
2008 36RLT Presidential Suites
Av8r1
As per CAT scales:
2005 Dodge 2500 CTD 48RE 4x4 Long Bed
2006 Keystone Cougar 281 EFS
The truck was full of fuel with two adults.
The trailer was full of water, propane, and loaded for camping.
Truck without trailer:
Steer axle = 4640 lbs
Drive axle = 2920 lbs
Gross wt. = 7560 lbs
Truck with Trailer:
Drive axle = 4420 lbs
Trailer axle = 7400 lbs
Truck Gross wt. = 9060 lbs
Trailer Gross wt. = 8900 lbs
Pin weight = 1500 lbs
GCVW = 16460 lbs
2005 Dodge 2500 CTD 48RE 4x4 LB
2006 Keystone Cougar 281EFS
ALBE
Please put in your truck specs ,per 4x4 ,crew cab,QC, truck model etc ,great info, scared to weigh my 1 ton dodge/35.5 newmare ,makes it squat ,tows like a dream, will weigh and post .
Albe
rdam
I weighed my trailer axles only, with WD hitch hooked up, to get a true reading of the actual weight on the tires. Came out at 8,660 pounds fully loaded with both motorcycles.
GVWR 11,560 lbs
Axle weight 6,260 lbs
Ship/Dry weight 7,420 lbs, which I doubt is accurate.
2006 Weekend Warrior LE 3505
2004 Ford F-250 Supercab SRW 6.0L Diesel/Auto
ryoung
2004 Dodge Dually, CTD, 6 speed, 4.10 gears, 30 gal. aux fuel tank. With 2 passengers, 65 gal fuel, 16K hitch, minimal tools.
The truck scaled at 8300 lbs.
Truck Ratings:
Front axle 4740
Rear axle 9350
GVWR 11500
GCVWR 23000
Fiver GVWR 15000
Last trip across the scales with the SunnyBrook:
Front axle 4620
Rear axle 6940
Trailer axles 11040
Total truck axles 11560
Combined truck and trailer 22600
Pin weight 3260
With the Lance TC loaded the truck scales at 11600 lbs. Dont have the axles weights handy but can look them up if someone would like to know. More weight obviously goes to the front axle.
ryoung
2018 Ram 3500 SRW Diesel
2019 Wolf Creek 840
CDLINSTR
2007 nbs 3500 srw 4x4 373 ratio reg cab 6.0 gas 6 speed auto factory gcvw rating 16000 lb coachmen 358 fiver gcvw of 14600 lbs ready to go water gas and propane full 20420 lbs- tow in 5th not 6th - 7 to 7.5 mpg average-I take my time and drop into direct on hills - trans temp no higher than 173- stops the same as the chevy dually I traded same brakes,axles and rear springs as the dually not the same as a duramax I traded but will do the job with proper care
CDLINSTR
bud4598
TV 06 Dodge 3500 dually full fuel and a few spare tires in bed
Steer axle=4640
Drive axle=3620
Gross axle=8260
Old Trailer
06 Sandpiper 37' dual slide, seperate garage
Weigh was on my way to trade in so totally empty
Steer axle= 4880
Drive axle= 6560
Trailer axle=9340
Gross= 20780
So Trailer weight = 12,520 pin weight=2,940
New Trailer
45' WW FULL THROTTLE with all options (8D batteries, 2 a/c, dual beds in garage, kicker sound, inverter, etc..
weigh was done as soon as I pulled out of dealership with no water and no gas in trailer but propane tanks full.
Steer axle= 4940
Drive Axle= 7760
Trailer Axle= 12860
Gross= 25560
So Trailer weight= 17,300 pin weight=4140
