โAug-21-2014 04:36 PM
โAug-25-2014 10:50 AM
โAug-25-2014 10:37 AM
โAug-25-2014 07:48 AM
โAug-25-2014 07:01 AM
โAug-25-2014 06:45 AM
Veebyes wrote:
Can't believe so many of you are apparently operating without levels permanently mounted for fore & aft plus side to side where you can't see them from your front leg switches.
You are running back & forth, inside then outside with a carpenters level. Really???
โAug-25-2014 06:23 AM
โAug-25-2014 03:47 AM
I have two level gauges (side to side) (front to back) within eye sight of the front jacks switch. First I align the side to side level with blocks under one side set of tires. Then adjust the front to rear until it is level. Has worked just fine for 8 years.
โAug-24-2014 03:07 PM
โAug-23-2014 08:56 PM
โAug-23-2014 05:20 AM
larry barnhart wrote:
what time is it??? I have 2- 6'8" levels and a different brand but yep I used them to install doors but when the doors cost in the thousands I used a plumb Bob. The more a door cost the easier it is to do a fine job. Pride is everything.
chevman
โAug-22-2014 08:33 PM
โAug-22-2014 06:18 PM
โAug-22-2014 06:16 PM
Rally's attended so far-21
โAug-22-2014 06:02 PM
