Where to jack
ijon1
Hi, I am going to change all four tires on my Fury 2910 toy hauler. My question is where should I place the jack and jack stands?
16 REPLIES 16
nayther
12th Man Fan wrote:
According to the axle mfg you should use the frame in front and behind the wheels.
I use a jack under the axle where the springs are bolted to the axle. I also use a board between the jack and the axles.
If your axles are on top of the spring pack you don't need the board.
Same here. But if you're pulling all 4 at once you may just want to raise the entire rig up on stands, just place the properly rated jack stands under the frame at the front and rear spring hangers. I'd drop my levelers or jacks as well. This always made me nervous, only did one side at a time.
DIRT BIKES RULE
'12 Duramax CC short bed
2019 Wildcat Maxx 285RKX
12th_Man_Fan
2014 GMC Duramax 4X4 DRW Crew
2015 DRV Tradition
