19.5 versus 22.5 tires
MURPHY55347
So I have had my Winnebago Vista 35F gasser for 3 seasons now. It feels like when driving down the road I'm constantly sawing back and forth on the wheel to make it go straight. Then factor in trucks and crosswinds and it can be quite a handful and quite tiring to drive. So far I have I have done nothing to the chassis. I read all the things that can be done to make it handle better, but I am wondering if anyone, with first hand experience, can tell me what part my having the smaller 19.5" tires might play?
What chassis upgrades aside from the CHF will give me the best bang for the buck to address my problems?
30 REPLIES 30
frankdamp
We averaged about 1800 miles a year in our rig. Sure it had a squirelly ride, but should I spend $2 for each of those miles for a relatively modest improvement or just spend the money on gas and CG fees?
For us, this was no-brainer. No amount of money can make a box-truck ride like a Cadillac.
If you're a full timer, or someone that does 15K or more a year in their RV, maybe spending some money on ride quality improvements is worth the trouble, but it didn't register a + on our preferences meter.
Frank Damp, DW - Eileen, pet - female Labrador (10 yrs old), location Anacortes, WA, retired RVers (since Dec 2014)
MURPHY55347
Alignment has never been done so it sounds like that should be my first step. Thanks you folks are awesome.
427435
I see people are still throwing band aid hardware solutions without the OP telling us if it has been recently aligned and if the caster is at 4-1/2 degrees or more.
That's all it took with mine (and new shocks).
Mark
2000 Itasca Suncruiser 35U on a Ford chassis, 80,000 miles
2003 Ford Explorer toad with Ready Brake supplemental brakes,
Ready Brute tow bar, and Demco base plate.
Effy
Why do you ask for solutions other than the chf? Have you done it already? If not, it could solve your issue for free. Made all the difference in the world and took 15 mins in the driveway.
2013 ACE 29.2
creeper
x2 on the steering stabilizer/ trac bar. Wind wandering can be lessened by front and rear stabilizers. It's such a common upgrade that the New Ford F53 chassis now comes with a very beefy front stabilizer. Not much wind wander on a 40 ft coach, i was impressed.
RayChez
That is why I got rid of my gasoline coach. It was a hand full with cross winds.
2002 Gulf Stream Scenic Cruiser
330 HP Caterpillar 3126-E
3000 Allison Transmission
Neway Freightliner chassis
2017 Buick Envision
Tom_Barb
America's highway are in the worst condition ever. I don't know a single vehicle that likes to track straight when the lane is dished out into ruts.
Try driving with two wheels near the white line. and stay out of the ruts.
427435
When was it last aligned and did the caster get set to at least 4-1/2 degrees?
Mark
Goldencrazy
I added steering stabilizer and rear trac bar on my coach with 19.5 wheels and 22. Made a nice difference on both. Thanks for the post as it reminds me I need to get it aligned.
wa8yxm
What part do the tires play.. likely none but.
First are the tires properly inflated, But this I do not mean the pressure molded into the side wall, nor the pressure on the sticker inside the RV NOR the pressure the dealer put in.
I mean scale the rig, each corner. so you know the load on the tire, then inflate each tire to the pressure specified for the load it is carrying (or that pressure plus 5 PSI, some folks (myself included) like to add 5 PSI)
Then you have 3 chassis issues that may need adjustment.
Sway "SIde to side rocking of the RV like fans swaying to the music at a rock concert while holding up their BICs) Sway bars control this, MANY RVs the factory sway bar is a bit anemic.
Wag: LEAF SPRING suspension allows the body to move side to side over the axles only a little bit,, but.. If the rear moves one way while the front moves the other and then they swap (Which they will) you think you are going down the road like this ~~~~~~~~~~~~~~~ so you try to compensat and as a result really do.. Had you not compensated you would have been going ============
TRAC bars stop this 100% completely control it (2 of them) just one may be enough I mean it makes a BIG difference
Steering stabilizers like the Blue-Ox True Center of the Safe-t-steer does a great job of assisting you in keeping to the straight and narrow. (And trust me when you are driving a vehicle that is 8'6" wide "NARROW" applies.. Only one other vehicle is allowed on the freeway (Save during construction) that size.. A flat bed tow truck (Ag Machinery which may be on Rual roads can be much wider but may NOT go down the freeway without special permits)
My Rig had decent Sway control but let me tell you a trac bar and stablizer made a BIG and I mean BIG difference.
chuckftboy
My last class A had 19.5's on a 35 foot coach and now I have 22.5's on a 36 foot coach. I noticed very little difference other than maybe the larger tires ride smoother. I have anti-sway bars front and rear and the coach rides just fine, even in a heavy side wind. Like others have said, alignment is one of the best ways to cure that side to side wheel correction. Inexpensively.
2019 Horizon 42Q Maxum Chassis w/tag
Cummins L-9 450 HP / Allison 3000
2006 Jeep TJ and 2011 Chevy Traverse Tows
Road_Dog
Your front end needs to be aligned! Try that before spending any money for add ons. All 5 of my motor homes needed an alignment to make them go straight down the road. Do this before anything else!
MURPHY55347
No we don't tow a car.
GrampaR123
MURPHY55347? Do you tow a car? And if so, do you notice any difference when towing and not towing? We notice much less "wander" when towing. It seems like our toad acts like a stabilizing anchor. Not that it would be a practical solution but I'm curious if other people have noticed the same thing.
And, on a previous rig with severe "wander" problems, after trying several remedies, a front steering stabilizer turned out to be the answer. At that time, more brands were available than just the Safe-T-plus at a much cheaper price. Safe-T-plus seems to be the only one sold currently, and they do a great job according to people who have installed them, but they're a little pricey.
Ductape
Get the front end aligned. That was the best money I ever spent. Have it done by a shop that does commercial truck alignments. Probably will need to have the caster adjusted, and that means unbolting the axle from the springs and inserting shims. Before ours took constant correction. Afterward you can stay on track easily unless you have to apply heavier pressure in which case we have the gearbox slop below.
Re the CHF- After extensive trialing different settings both drivers agree we get the best handling with the rear antiroll bar in the inner holes (most stiff) and the front antiroll in the outer holes (less stiff). Stiffening up the front antiroll made the coach more sensitive and less inclined to track straight. Probably not true for all coaches.
I installed a rear track bar. Honestly felt no change from that.
Next issue to address is the steering gear box has some free play in it. If the direction of the road crown changes or the wind and you have to go from holding left to holding right then there is 2-3" of play at the rim of the steering wheel before the gear takes up the slack. I'm going back to Ford for that and insisting on a new steering gear.
I also find directional stability is better at 90 psi in the tires. That's what Newmar recommends. Following the usual advice to weigh and then air accordingly we ran a lot of miles at 80 psi. At 80 it rides more smoothly but has less stability. I'm going to try it one time with 100 in the rears just to see what the difference is. There is a clear tradeoff between smoothness and stability when it comes to pressure.
YMMV. Good luck!
49 States, 6 Provinces, 2 Territories...
