2004 fleetwood revolution aux start relay
sew0177
Can anyone tell me where the 2004 fleetwood revolution aux start relay is located. I needed to use the feature but would not work...chassis batteries might have been to low.
2 REPLIES 2
RLS7201
Your Aux start/isolator relay will be close to your Battery Control Center (BCC). Which should be with in 6' of your batteries. Fleetwood keeps moving things around but I think all the above mentioned items are on the left, close to the rear.
Richard
95 Bounder 32H F53 460
2013 CRV Toad
2 Segways in Toad
First brake job
1941 Hudson
WILDEBILL308
I can't butI know someone who can. Call FLEETWOOD: Parts, Service & Technical Support
800-322-8216
If you think the batterys are low can you plug the coach in? If not start the genarater and let it run for atleast an houer and see if it will start then.
Bill
2008 Newmar Mountain Aire
450 HP CUMMINS ISM
ALLISON 4000 MH TRANSMISSION
TOWING 2014 HONDA CRV With Blue Ox tow bar
A man who carries a cat by the tail learns something he can learn in no other way.
-Mark Twain
