โFeb-25-2018 01:24 PM
โMar-03-2018 06:08 AM
GHOST1750 wrote:
I'm getting ready to move to Newmar and sad feelings about leaving the National family.
โMar-02-2018 09:42 PM
โFeb-28-2018 04:53 PM
wildmanbaker wrote:
You mentioned you had a leak in the driver's area. Check the front clearance lights, as they can be a source of leakage. Use the self-leveling caulk around them.
โFeb-28-2018 10:40 AM
โFeb-27-2018 12:20 PM
TechWriter wrote:
Here are some of my SeaBreeze docs that you might find useful:
- National SeaBreeze 8431 wiring
- National RV Vendors (released when National RV went Chapter 11 in 2007)
- National RV 12V/120V Wiring (all systems)
- National RV Plumbing Systems
- National RV Heating System
- National RV Hot & Cold Plumbing
- National RV LPG System
- 600W Inverter Option
โFeb-27-2018 11:04 AM
โFeb-27-2018 02:26 AM
โFeb-26-2018 11:38 AM
TJHUB wrote:
To be clear on the levelers, the rears donโt want to retract all the way without assistance from a prybar of some sort.
โFeb-26-2018 10:57 AM
โFeb-26-2018 10:50 AM
jerseyjim wrote:
Good advice above, I can only add something regarding the lack of 110 in the bedroom outlets:
I have a 2001 Dolphin which is, I think, 1 step above the Seabreeze. For whatever reason, NationalRV had the very front outlets (TV and coffeemaker outlets) on the same circuit as the 2 bedroom outlets. They were controlled by the INverter. (Not to be confused with the CONverter) Presumably you have an INverter. If you do, check the circuit breaker on that. That could be your problem.
((Note: last fall, my INverter failed, and seeing I never used it, I removed (bypassed) it. Everything works fine, I just have to remember not to put any really heavy draws (like a space heater) on those outlets. No biggie.))
Stay with Fantastic Fan. Excellent customer service. So is their product.
G'luck!
โFeb-26-2018 10:47 AM
GREGORYJ wrote:
Because its a fiberglass roof, its much easier to fix than a rubber roof. You can scrap off the old caulking with a putty knife without worrying about damaging it like a rubber roof. You can also completely clean off remaining caulking with varsol which you cannot use on a rubber roof. Replace all vents assemblies, even washroom vent assembly with motor, not too expensive. Use Dicor roof calking to re-seal vent assemblies and joints between front and rear caps, shower skylight,etc. maybe even replace the Fantastic fan as it uses a plastic frame which may be cracked and can leak.
As mentioned, the roof is the most important fix that should be done before using and risking water leaks.
Use an oxidation remover like Meguiars Mirror Glaze #49 Oxidation Remover Heavy Duty Cleaner to clean up and bring a shine back to any outside areas that look bad like lower doors, rear cap, lower fascia, etc. Don't sand.
The hydraulic levelers have springs that retract them. Try spraying silicon lub
on the hydraulic levelers when extended, this may allow them the retract correctly.
Not sure of the no AC problem on rear slide, Check AC breaker panel for tripped breaker to start with.
โFeb-26-2018 10:40 AM
ArchHoagland wrote:
4. The hydraulic levelers are slow.....Spray with WD 40 or use transmission fluid on them. I lube mine every year.
6. Do I want a Sewer Solution...... NO
8. The engine A/C doesn't work....can be anything from low on R134 ($20) to a bad compressor ($1200).
You should convert the transmission fluid to Transynd if it hasn't been done already.
โFeb-25-2018 11:44 PM
โFeb-25-2018 08:55 PM
