A buddy of mine is looking at buying a 2005 Fleetwood Discovery J model. It has 27,500 miles on it and has been garage kept. Coach looks great. The problem is we can't get the generator to start. It had bad batteries, and new ones have been installed. But it will not turn over. The dash switch does not light up when you push it to start. The switch on the generator will light up and throw a code. at first it was 3 rapid flashes followed by a hesitation and then 3 more rapid flashes. Once i get it in the mode to check it will flash code 4-6. The batteries are fully charged and wired correctly. can't figure out why it will not start and why I don't have an indicator light on dash switch but I do have it on generator switch. The owner said he has never had an issue with it starting until the batteries went bad. My buddy knows the owner real well, so we know he is on the level with us. We had found some of the electrical things were not working, but that was due to a tripped GFCI circuit. Any help is greatly appreciated.
Brian & Neena & B.G.
B.G. 2014 Goldendoodle
2007 Coachmen Cross Country 389DS
300 HP Cummins Turbo Charged
03 Sahara Jeep Wrangler & 05 Harley Davidson Ultra Classic
2014 800 RZR4
Roll Tide Roll
