2006 sprinter not starting
arvie
My 2006 ltv sprinter not starting two days in a row. Battery is good but key won't engage the starting process. Yesterday it started after I reinserted key and jiggled the shifter. Today 3 people failed to start it. Was towed and works in the garage. Any ideas? Ignition or starter? Thanks.
7 REPLIES 7
arvie
Fortunately I am near a dealership but I am reluctant to head down to Big Bend until the problem is resolved.
mobilefleet
sounds like bad starter to me. check for loose battery cables or corroded cables too
My_Roadtrek
Sounds like moisture may be causing the problem, it dries out, circuit closes, then runs fine. Can be hard to pin point, but I would check the wires for Rodent damage.
Mandalay_Parr
Might have a loose or poor connection somewhere.
Probably real hard to find.
Jerry Parr
Jerry Parr
Full-time
2005 Mandalay 40B
Cat C7 350, 4 Slides
Blue Ox, Brake Buddy
2004 CR-V Toad
jrparr@att.net
602-321-8141
K7OU - Amateur Radio
Kenwood Radios
ARRL, W5YI, & LARC VE
SKYWARN Weather Spotter
arvie
Mercedes can't find anything wrong and tested everything. It works great in the garage. We are leaving it outside overnight to get cold and test again in the morning. I am at a nice hotel. The dealership is great outside St Louis. Thanks for your suggestions.
enblethen
Neutral safety switch
Is your ignition key equipped with an electronic sensor? Turn key over and try again
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
Mandalay_Parr
Shifter neutral switch also.
Jerry Parr
Full-time
2005 Mandalay 40B
2004 CR-V Toad
jrparr@att.net
602-321-8141
Kenwood Radios
