โJul-12-2020 05:10 PM
โJul-14-2020 09:56 AM
โJul-13-2020 12:52 PM
bobndot wrote:
Drew, you might be correct, I don't know about those winterizing connectors. Do you think it might be an older version of the aftermarket BT connector kit, like the one in this link ?
The below link shows a pic of a slightly different model that uses a white smooth plastic coupler instead of the older models white 'star' plastic coupling that is shown in the OP's pic, which is a threaded hose connector.
โJul-13-2020 10:44 AM
ronfisherman wrote:Karhoot wrote:IAMICHABOD wrote:
Could this be the Fresh Water Tank fill location,the on board water tank is located at the rear under the bed.
Nah the fresh water fill is what my hose is currently hooked to.
How does your RV fill Fresh Water TANK?
Post another picture showing label to right.
โJul-13-2020 08:29 AM
โJul-13-2020 06:53 AM
โJul-13-2020 05:04 AM
Karhoot wrote:MDKMDK wrote:
Hook up a dirty (non-potable) hose to it, open your black tank valve, and turn on the hose.
So is it usual that the flush has a different size hose attachment?
And how would I be sure that, that is infact the flush? I would hate to introduce city pressure to something that isn't suppose to be pressurized.
โJul-13-2020 04:22 AM
โJul-13-2020 03:09 AM
โJul-12-2020 10:13 PM
โJul-12-2020 10:12 PM
โJul-12-2020 08:59 PM
โJul-12-2020 05:41 PM
