I have a 2008 Damon Daybreak 3276 with a loose drivers side mirror. The 4 screws are tight when I checked, not sure if any others have had this issue before.
The mirror noticeably bounces when going down the wonderful Michigan roads, the passenger side does not do this. When you go outside you can move the entire mirror up and down and the side wall of the MH flexes a little.
My next step was to remove the screws and take it off but I thought I would throw it on here first. I did check from the inside to see if I could feel or see anything and it appears normal.
2013 Newmar Canyon Star 3940
2017 Jeep Wrangler
