2010 Challenger. Turn signals- brake lights on tow
LizzieB
We have lights for the brake and turn signals on the car but there is a problem with the connection from the RV to the car. When hooked up, the signals don't work on car. Any suggestions?
4 REPLIES 4
Effy
That's why I opted for an independent set of lights. Does not interfere with the car at all.
2013 ACE 29.2
Dog_Folks
80% of these troubles are caused by a bad ground.
Make sure you have a good ground and then go from there.
Our Rig:
2005 Dodge 3500 - Dually- Cummins
2006 Outback 27 RSDS
We also have with us two rescue dogs. A Chihuahua mix & a Catahoula mix.
"I did not get to this advanced age because I am stupid."
Full time since June 2006
lanerd
Probably a bad ground connection somewhere. When ever I have a light problem, I always look there first. 9 out 10 times, that's the problem.
Good luck in finding it.
Ron
Ron & Sandie
2013 Tiffin Phaeton 42LH Cummins ISL 400hp
Toad: 2011 GMC Terrain SLT2
Tow Bar: Sterling AT
Toad Brakes: Unified by U.S. Gear
TPMS: Pressure Pro
Member of: GS, FMCA, Allegro
RETIRED!! How sweet it is....
tessa25
Lol. I found out this morning I have the same problem. I can even hear a relay clicking in the car when the turn signal is on. But no lights. Didn't have time to debug this morning.
Palomino Gazelle G150
