Apr-19-2015 04:33 AM
May-26-2015 05:36 PM
May-26-2015 05:00 PM
Apr-19-2015 05:38 PM
LennyH wrote:
Hi Chris
The holding tank for fresh water is located above the third bay door on the right side on the RV, after you open the bay door you have to remove the panel on the top of the compartment and there you will see the holding tank, Hope this helps.
Lenny
rcmiller32 wrote:
Not sure on your model, but on our 2014 Coachmen Pursuit the black tank sits right under the toilet and the gray tank runs crossways behind the black tank. The wet bay has the furnace line blowing in to warm the compartment. They took the 4" line and put a tee into it. Then there is a 2" line ducted down into the compartment.
You might have to remove or move the panel in that compartment to see were the tanks are. At the least to follow the piping.
Apr-19-2015 06:46 AM
Apr-19-2015 05:31 AM
Apr-19-2015 05:27 AM
Apr-19-2015 04:37 AM
