2014 Southwind 32vs Roof Type?
mdecastra
Does anyone know, for sure, what kind of roof comes with 2014 Fleetwood Southwind 32vs. Prev Owned did not tell me.
7 REPLIES 7
mdecastra
I went up and it appears to be fiberglass. There appears to be a 'frame around it'. For example, the front and back ends fit into end pieces that may not be fiberglass. When I knock it, it seams hard like fiber glass.
Any suggestions on how to take care of it?
For the first 2 years, it will be outside(100%). I plan to build a garage for storage, this winter, and it will be out only when on the road.
Valkyriebush
edstep wrote:
I have a 2014 Southwind and it is fiberglass (34A)
That's a good move on Fleetwood's part!
OP If yours is fiberglass you should be able to tell easy?
Command Master Chief (AW) USN, (ret)
2003 Fleetwood Excursion 330 Turbo Cat 39D
2000 Jeep GC
2005 Big Ruckus (Rides Behind Jeep)
2003 VTX 1800
edstep
darsben
You need to look for rips, tears, loose seams and Areas that have deteriorated specially around vent, pipes, cargo carrier and antenna protrusions. Some EPdm need cleaning and reconditioning every so often.
Traveling with my best friend my wife!
mdecastra
what do I look for when I get up there and what kind of maintenance does it need?
Valkyriebush
Probably EPDM or TPO.
2000 Jeep GC
2003 VTX 1800
donn0128
Climb up and look. Easy to see the difference between fiberglas and epdm
