โJun-23-2020 10:26 AM
โJun-24-2020 03:35 PM
โJun-24-2020 02:13 PM
Bikeboy57 wrote:
No one is addressing the performance issue. Having had both, the 110v dryer is Not even close to half the drying performance of the 220. The CFO says 220 dryer is mandatory anytime I start looking at coach porn.
โJun-24-2020 11:16 AM
โJun-24-2020 10:42 AM
โJun-24-2020 10:16 AM
valhalla360 wrote:
I believe it would be harmless but if you connect to 30amp with an adapter, both hots on the 220v circuit in the camper will be connected to the same pole, so you would see zero voltage.
Anyone correct me if I'm wrong about the safety aspect?
โJun-24-2020 09:02 AM
โJun-23-2020 08:16 PM
Second Chance wrote:
Our Whirlpool stacked pair are both 110V - and the same size as the Splendide stackables.
Rob
โJun-23-2020 06:06 PM
โJun-23-2020 02:45 PM
dougrainer wrote:
Yes, it is possible. Hi end Class A diesel builder's sometimes include a 220 circuit for a dryer. The 50 amp panel has the 2 separate 120 phase inputs to run the 220 circuit. You just have to run the wiring from the breaker panel to the Washer/Dryer closet. The reason the Builders do not include is COST. Lack of really needing a 220 dryer is the other. Doug
โJun-23-2020 02:25 PM
โJun-23-2020 02:20 PM
โJun-23-2020 02:15 PM
โJun-23-2020 02:09 PM
