โFeb-06-2014 01:05 PM
โFeb-07-2014 06:31 AM
wny_pat wrote:tinkerer wrote:And there in lays the answer! The torque curve of a diesel covers a much wider RPM range that the gas engine does. The diesel requires less shifting when going up a hill because of the wide torque curve.
the hemi has a lot of power but is constantly hunting for right gear because it's torque curve is small. I really don't care what other say about gassers as I go by the seat of my pants and the diesel wins hands down, JMHO.;)
โFeb-07-2014 06:27 AM
โFeb-07-2014 06:03 AM
โFeb-07-2014 05:47 AM
โFeb-07-2014 04:38 AM
rgatijnet1 wrote:tempforce wrote:
one thing they forgot to mention above and in the test...
how long the engines will last and how much fuel each used to perform the test...
the diesel will usually last between 750,000 to 1 million miles before overhaul... the gas engine should last around 150,000 - 200,000 miles...
also the diesel engine will usually get 1/3 to double the mileage of the gas engine, with the same gearing/load ect.
Yep, I'm sure that Motor Trend could have modified the test so that the diesel performed better. Maybe change the gearing, load the gas coach more, etc. Since you brought up mileage, according to the test, the diesel got 18MPG max and the gas engine got 17mpg max. Not a huge difference, especially since diesel fuel costs more The OP asked for a comparison with all variables being equal. The Motor Trend test was pretty equal as to comparing the two different types of engines.
โFeb-07-2014 04:34 AM
โFeb-07-2014 04:32 AM
โFeb-07-2014 04:28 AM
โFeb-07-2014 04:22 AM
somewhere in the texas 'lost pines'
โFeb-06-2014 07:58 PM
โFeb-06-2014 07:19 PM
Ivylog wrote:What's to figure out? Oh, so you're saying that they should've made their test even more unscientific by giving one of the engines an advantage?
I'll bet the Motor Tend test was done close to sea level. I'll let you figure out the rest of a story.
DougE wrote:So full throttle with a trailer in tow isn't a load?
Quarter mile performance is mainly a horsepower and gearing thing. I wish they had done a high gear only hill climb up a long 5% or better grade.
โFeb-06-2014 06:53 PM
โFeb-06-2014 06:39 PM
Stealth1 wrote:You forgot smell, shake, oil on carpet, and last but not least, smoke.
In a word: TORQUE!!
โFeb-06-2014 06:33 PM
โFeb-06-2014 04:54 PM
rgatijnet1 wrote:
The same diesel engine could probably pull 10,000 pounds more than the gasser but the test just shows that all things being EQUAL, the gasser will out perform the diesel
