Jun-16-2014 09:16 AM
Jun-20-2014 04:36 AM
Deano56 wrote:When I switched to syn oil on my tow car it caused the pan gasket to leak I tighten the pan gasket bolts 3 times over a year to stop the leak. It may not take the gaskets out but it cause them to leak. The car had 80k on it at the time the MH had 30k on it when I switched and did not leak.
different types of oils do not take seals out, myth. Many switch to the newer synthetics , they don't boil off
Jun-20-2014 03:41 AM
Jun-20-2014 02:22 AM
Jun-19-2014 11:22 PM
Jun-19-2014 08:26 PM
Jun-16-2014 04:54 PM
Jun-16-2014 03:05 PM
Born To Travel wrote:From my previous post I don't want to run syn in an 18 year old trans with 99 k miles on it. I decided to go with the Super Tech(Dextron/Mercon) from Walmart that is compatible with Dextron 3, which was nowhere to be found in my area.
You can use Dex 6, as it is backwards compatible.. But it is at the lower level for viscosity, Meaning it is already as thin cold as Dex 3 is hot... Do you really want that in a engine compartment that runs as hot as the enclosed engine in an RV?.. I run Dex 3 in my 1995 4l80e in my RV..
Jun-16-2014 01:59 PM
Jun-16-2014 01:00 PM
Jun-16-2014 10:11 AM
Jun-16-2014 09:48 AM
Jun-16-2014 09:47 AM
Jun-16-2014 09:41 AM
MountainAir05 wrote:My last chg was about 4 years ago. Fluid still looked good and very little stuff on magnet inside pan but was 30k miles since last fluid chg. Dextron VI is a syn fluid and my trans has 99 k miles on it and does not leak. I do not want to create any leaks now.
Dexron VI is what is current. Read up . Have not seen 3 in many years here local.
Jun-16-2014 09:37 AM
Born To Travel wrote:tried another Auto Zone and all they carry is Dextron/mercon also. Thanks for the pan torque I had to soak mine in Kroil oil several days to loosen them. I have broken to many small bolts.
Try some other auto parts stores.. Dexron 3 is one of the most popular trans fluids out there... You are just getting bad advice... Also final torque the pan bolts to 10 ft pds. to keep from distorting the sheet metal pan...
