6.8L V-10 Ford fuel question???
Desert_Captain
I think I know but can anyone confirm what grade of gas the Ford 6.8L V-10 requires? We are shopping for a 24 - 26' Class C and the Ford is my first choice. I am finding a few units that offer the 6.0 Chevy so the original question applies here as well. Any thoughts on the Ford/Chevy for a Class C? :h
13 REPLIES 13
2001_Ford_E450
87 octane. That is all I have used and it runs fine.
mrnoyb
page 124 of the owners manual...
Regular unleaded gasoline with a
pump (R+M)/2 octane rating of 87
is recommended.
grampachet
Tryed supreme with no difference, use regular always.
2004 F-250 KIngRanch,CC,SB,SRW,4x4,V-10,3.73
2008 Montana 3000RK
kycliff
Have a 2005 four Winds with a 2004 f-450 V10 runs fine with 87 octane but better on 89
Mich_F
My V10 is supposed to run on 87 octane, E85 is not to be used.
2014 Itasca Spirit 31K Class C
2016 Mazda CX5 on Acme tow dolly- 4 trips ~ 5,800 mi
Now 2017 RWD F150 with a drive shaft disconnect
mlts22
I don't know about the Chevies, but anything less than the cheap stuff is actually bad for the Ford V-10s, unless the V-10 has a custom-programmed tune to be able to have the correct valve timing for the higher octane.
I've fiddled around with grades of gas with my old F-150. The expensive stuff got me the same MPG as the cheap stuff. My new F-150, I have been messing around with E85, and it does seem to have a little bit more HP (butt-dyno measurements), but MPG numbers are not a pretty sight.
My take: Use the cheap stuff, or see about a tune and programmer that can make the engine use the higher octane fuel. I've read about people finding that the MPG gain from the higher octane fuel tunes more than offsets the higher pricetag. However, one's milage will vary, and tunes can differ.
Oh and use tunes at your own risk. They can damage an engine.
n7bsn
mlynds wrote:
I found mine gave better mileage and more power with the higher octane fuel
While I found (two different units with different variants of the 6.8 V10) no difference.
2008 F350SD V10 with an 2012 Arctic Fox 29-5E
When someone tells you to buy the same rig they own, listen, they might be right. When they tell you to buy a different rig then they own, really pay attention, they probably know something you don't.
K_Charles
87 in mine too
hilldude
I likes regular and lots of it.:)
mlynds
mockturtle
Yep.
2015 Tiger Bengal TX 4X4
Chevy 3500HD, 6L V8
fla-gypsy
87 Octane
This member is not responsible for opinions that are inaccurate due to faulty information provided by the original poster. Use them at your own discretion.
09 SuperDuty Crew Cab 6.8L/4.10(The Black Pearl)
06 Keystone Hornet 29 RLS/(The Cracker Cabana)
IAMICHABOD
The manual on my Class C 6.0 Chevy states " Regular Grade 87 Octane"
If that helps..........
That is what I use.
Former El Monte RV Rental
Retired Teamster Local 692
Buying A Rental Class C
