800 hours on an 1987 Onan genset. Rebuild engine?
JimInMich
My 1987 Onan 6700 watt/50amp genset shows just shy of 800 hours use. Nothing's wrong with it so far, just wondering how many hours of use I can expect, before it's going to need a engine rebuild. I know that's subjective to how it's been maintained in the past.
Current: 1987 Georgie Boy Encounter 34',John Deere chassis,460c.i./C6.
SOLD-2012 Cougar XLite 27RLS
SOLD-2008 Aerolite 24FB
SOLD-2004 Shadow Cruiser Fun Finder 189FBR
Just the Wife and I.
14 REPLIES 14
Canadian_Rainbi
Sounds like high school: "RUMBLE!"
hanko
here we go
2014 Tiffin Open Road 36LA,Banks Power pack,sumo springs, 5 star tune, magnum invertor
2013 Ford Focus Toad
Haigh Superstar
Wills6_4_Hemi
JimInMich wrote:
Trackrig wrote:
That's sort of like saying you're going to rebuild the MH engine even though there's nothing wrong with it.
Bill
Dont be rude. I know something about vehicle engines, nothing about these small engines. I wasnt sure if 800 hours was a lot or not, thats why I asked.
x2 if you have nothing worth adding just don't post anything IMHO
Trackrig
JimInMich wrote:
Bill
As a Senior Member, you should have read several of the posts that pop up every three or four months discussing how many (or lots and lots of) hours people have on their gen sets that are still running fine
Bill
Nodwell RN110 out moose hunting. 4-53 Detroit, Clark 5 spd, 40" wide tracks, 10:00x20 tires, 16,000# capacity, 22,000# weight. You know the mud is getting deep when it's coming in the doors.
JimInMich
Bill
sdbounderdiesel
I have an Onan 8000 Quiet Diesel with over 2000 hours on it. So far, just routine maintenance iaw the service manual. No need for a rebuild at only 800 hours. The one thing I would suggest to you is to take a good look at all the hoses. If they are more than 6 or 7 years old, it might be time to change them out with fresh rubber. Good Luck!
Trackrig
Bill
JimInMich
Sounds good guys, thanx.
Bill_Satellite
My generator is just shy of 10,000 hours and still working great. It has has some minor work done but as long as the genset works as expected there is no reason to believe that anything other than normal maintenance needs to be done.
Can't we all just get along?
MrWizard
Moderator
Moderator
Save the money
Use it for something else
Rebuild NOT needed yet
I can explain it to you.
1997 F53 Bounder 36s
moisheh
10,000hours on gas genset is a lot of hours. 800 is nothing.
Moisheh
Jim_Norman
at 800 hours assuming reasonable maintenance, your genset is hardly broken in. you will more likely have issues from lack of use long before you wear it out. You need to run it 2 hours a month under load. This keeps everything lubes and pliable Seals don't take a set etc.
2016 Tiffin Allegro Red 38QBA
2008 Jeep Liberty (aka FireToad)
Ivylog
I thought you left off a 0...8000 hours.
Upgraded with a 08 HR Navigator 45โ€™...
Mandalay_Parr
Maybe 10,000 - 15,000 hours.
800 is nothing.
Jerry Parr
Full-time
2005 Mandalay 40B
Cat C7 350, 4 Slides
Blue Ox, Brake Buddy
2004 CR-V Toad
jrparr@att.net
602-321-8141
K7OU - Amateur Radio
Kenwood Radios
ARRL, W5YI, & LARC VE
SKYWARN Weather Spotter
