Where are you right now? If anywhere near Whitney, TX I could help you take a quick look and try to determine why the compressors aren't starting.
Did everything work right after you had the circuit board replaced? If so, as others here said, the problem could be the start capacitor or possibly the relay for the #1 compressor. The #2 compressor doesn't start until a minute or so after #1. Have you checked the circuit breakers? You might try turning off the #2 circuit breaker, and see if #1 will start and run then. Not likely, but it's worth a shot.
gfs1943
USAF, Retired (1962 - 1983)
2006 Monaco Diplomat 40PRQ
2006 Honda CR-V
