I had been using both AC fans just the fan not the AC for a couple days when I went to turn the front AC fan on it just hums and the fan dose not turn on dose anyone know what I should look for on this problem??
1999 Pace Arrow 37s F53 Triton V10 8 to 9 mpg 6 to 7 with toad
The fan in my 1999 Winnebago Chieftain would do the same thing, as well as shriek sometimes. Removing the cover and spraying some lube into the motor would free it up and work for a time. Did this many times over the last 2 years. It finally froze up and wouldn't restart. Copied the Manufacturer name and model # off the ID plate on the motor. Found a new one on Amazon. Replaced it. Now it runs like a champ. Should have done it 2 years ago. BTW, I had Camping World check it on my maiden voyage. They estimated about $1200. Turned them down. The motor I needed was only $179 on Amazon.
Seized shaft Insect/bird next in fan/blower assembly jaming it
And that about covers it,
Home was where I park it. but alas the. 2005 Damon Intruder 377 Alas declared a total loss after a semi "nicked" it. Still have the radios Kenwood TS-2000, ICOM ID-5100, ID-51A+2, ID-880 REF030C most times
