โApr-04-2015 10:09 AM
โApr-08-2015 10:55 AM
wa8yxm wrote:Why bother putting these thermal switches in if the motor overheats and is damaged by the time the switch shuts of?
However when the Thermal Cutout (no matter the brand name) Cuts out...The motor is ALREADY OVER HEATED. And thus Damage has been done.
Plus there are more things than windings that can "Burn out".
Low voltage is a motor killer.
โApr-06-2015 04:22 PM
โApr-06-2015 03:46 PM
โApr-06-2015 03:31 PM
Coyote74 wrote:. That's why I asked if these switches could be bought to shut off at 108 v. They seem a lot cheaper than the surge guards. I have heard several people say their surge protectors did not protect them from this kind of low voltage. I am not sure how quick these switches work but it sounds like if they shut off fairly quickly you could add one that would cut out below 108 v and over 130v and your AC would be protected or even add one to your main power supply to shut off all the power to the MH. Am I missing something basic here?
I have a 2004 winne adventurer with basement air. I also use a surgegard protector. I was in a park and low voltage happened where air was running and I was outside getting a extra chair out for guests and I smelled plastic burning.apparently the power was down to 104 or 105 volts about an hour and the damage happened.The ac burned up 2 run capacitors, a printed circuit, and 2 start capacitors. The wire harness had to be replaced too.
the surgegard doesnt cut low voltage until 102 volts. Anything under 108 can damage appliances.It did mine. Now I own A huges autoformer to increase voltage when needed.I now use them both autoformer at the pedestal first and then surge gard just before the MH plug.now its protected!
โApr-06-2015 02:08 PM
โApr-05-2015 10:46 AM
jhilley wrote:Old-Biscuit wrote:
Actually the 'klixon' is a thermal overload
No, it is a temperature rated pressure switch.
Klixon HVAC Pressure Switches
โApr-05-2015 08:54 AM
โApr-04-2015 11:34 PM
โApr-04-2015 11:31 PM
โApr-04-2015 10:28 PM
โApr-04-2015 07:35 PM
โApr-04-2015 12:12 PM
โApr-04-2015 10:43 AM
โApr-04-2015 10:39 AM
