AC Low Voltage Protection.
Gjac
I had read a while back about AC's having built-in protection from low voltage by having a switch that cut off the AC before damage occurs. Does anyone know more details than this, and where it is located and what does this switch look like.
15 REPLIES 15
Gjac
wa8yxm wrote:
However when the Thermal Cutout (no matter the brand name) Cuts out...The motor is ALREADY OVER HEATED. And thus Damage has been done.
Plus there are more things than windings that can "Burn out".
Low voltage is a motor killer.
Why bother putting these thermal switches in if the motor overheats and is damaged by the time the switch shuts of?
chuckftboy
Old Biscuit is correct that when a Klixon thermal-disk is used on a compressor, it opens on temperature. Klixon is a brand name and they also make other compressor controls such as pressure switches and relays. Temperature goes up when amperage increases due to low voltage but a thermal disk will also open when the compressor shell gets too hot from reduced air flow, low refrigerant, ect.
2019 Horizon 42Q Maxum Chassis w/tag
Cummins L-9 450 HP / Allison 3000
2006 Jeep TJ and 2011 Chevy Traverse Tows
wa8yxm
Gjac
Coyote74 wrote:
I have a 2004 winne adventurer with basement air. I also use a surgegard protector. I was in a park and low voltage happened where air was running and I was outside getting a extra chair out for guests and I smelled plastic burning.apparently the power was down to 104 or 105 volts about an hour and the damage happened.The ac burned up 2 run capacitors, a printed circuit, and 2 start capacitors. The wire harness had to be replaced too.
the surgegard doesnt cut low voltage until 102 volts. Anything under 108 can damage appliances.It did mine. Now I own A huges autoformer to increase voltage when needed.I now use them both autoformer at the pedestal first and then surge gard just before the MH plug.now its protected!
. That's why I asked if these switches could be bought to shut off at 108 v. They seem a lot cheaper than the surge guards. I have heard several people say their surge protectors did not protect them from this kind of low voltage. I am not sure how quick these switches work but it sounds like if they shut off fairly quickly you could add one that would cut out below 108 v and over 130v and your AC would be protected or even add one to your main power supply to shut off all the power to the MH. Am I missing something basic here?
Coyote74
Joe Taylor , Good Sam Life Member
FMCA #285032
2004 Winnebago Adventurer 38R
Life's a trip, RVing makes it an incredible journey.
Old-Biscuit
jhilley wrote:
Old-Biscuit wrote:
Actually the 'klixon' is a thermal overload
No, it is a temperature rated pressure switch.
Klixon HVAC Pressure Switches
Klixon used for both PLUS.........LINK
As used on RV A/C Units....compressor motor 'thermal-0verload'.....LINK
jhilley
2003 Winnebago Adventurer 38G F53 Chassis Solar Power
1999 Winnebago Brave 35C F53 Chassis Solar power
Handicap Equipped with Lift & Hospital Bed
1999 Jeep Cherokee Sport
1991 Jeep Wrangler Renegade
Old-Biscuit
camper19709
Never heard of that. I use a Hughes Autoformer.
Chip
06 SurfSide
30ft class A
2 slides
Ford V10 chassis
04 Chevy Astro van toad
jhilley
Those are pressure switches for high pressure and low pressure cut-out.
Gjac
Good Sam RV Club Member
Offline
Posted: 03/17/15 11:17am Link | Quote | Print | Notify Moderator
"there is a thing on every air cond compressor called a klixon that heats up at the same rate the windings in the motor do. If in a brownout period the voltage goes down, then the amperage goes up. Fact or law of electric. the klixon will snap off until it cools and then snap back on. It should (repeat should) prevent the AC from turning to toast.If you hear the compressor cycling, turn it off.For best insurance, buy a Progressive EMS and it will turn off the electric for you. Absolute peace of mind for a couple hundred bucks."
I found what I read a while back copied above, I had not heard this before either but found it very interesting. Apparently Klixon makes a lot of switches. Sounds like if you could put one in that shuts off at 108 volts the AC would be protected from low voltage, I was hoping some electricians could comment.
2oldman
Never heard of that on an a/c unit.
wa8yxm
I too am not aware of any such Air Conditioner.
I have a Hughes auto-former.. This device will boost low voltage if it can,, and if it can not boost enough then a Surge Protector such as the Progressiv Industries job in the last post.... Very good product.
Old-Biscuit
Yes an EMS will protect from low voltage/high voltage events by cutting power off until voltage is back within limits----103V t0 132V.
Problem is AC motors can incur damage at 108V.
I have a Progressive Industries unit and it has found 'reversed polarity', 'open neutral' and has cut power during low voltage excursions BUT I actively monitor AC voltage in rig and I shut down AC when voltage is low at 108V.
Need be I'll run generator until voltage improves.
