Air dryer cycling too often ?
Dog_Trainer
I noticed my Air dryer for my compressor was cycling often on our last trip. When I drained the air off both holding tanks before and during the trip I did not notice any moisture. When I say Often the dryer seems to be cycling about every 30 seconds or less. This is evidenced by the air noise of the blow off valve. My air stays pretty steady at about 150 lbs both tanks when running. No noticed leaks and both tanks have pressure from overnight. I did put new filter media in it a while back but maybe time to service it again. Maybe the air compressor is staying on too long. Any information is always appreciated.
2016 Newmar Baystar 3401
2011 HHR Toad
Daktari & Lydia Cavalier King Charles , Annie get your guns, our English setter (fur Bearing Children)
10 REPLIES 10
mtrumpet
I don't know what air dryer System you have on your rig, but here's a link to the Meritor Wabco web page which will get you to all of their technical literature and troubleshooting guides which may at least help to point you in a direction to find the cause of your problem.
Meritor Wabco
ON EDIT: Sorry, I couldn't get the link to go directly to the literature page, so the above link will take you their main page. Just click on the "Literature" tab, then click on "Air Dryers".
150 psi is high for the air system. Shouldn't be running higher than 120/125 psi max, regardless of which system is used on your chassis.
Just off the top of my head, I'm thinking that the problem may be with either the air governor or pressure relief valve at the air dryer. However, as Brett Wolfe mentioned, the wisest place to start would be with your chassis manufacturer for the most accurate information. They most likely would have an idea as to what the problem may be.
Mark & Cherie
2002 Newmar Dutch Star DP 3872, Cummins 350 ISC, Spartan Chassis
wallynm
Air dryer could need servicing.
Have a Diesel Engine Diesel RV Club
Have a Freightliner FCOC Web Page
Living on the memories now
EX 02 DSDP 3567
EX 99 Coachmen
EX 86 Georgie Boy
EX 75 Winnie
EX 72 Sightseer
EX 68 Brave
THOSE THAT DO NOT KNOW HISTORY ARE DOOMED TO REPEAT IT
wolfe10
OP,
Contact your chassis maker with your VIN. They can tell you the correct PSI range for your air system.
If it is incorrect, most air governors are easily adjustable.
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
Dog_Trainer
deandec wrote:
Depending on the Air Dryer, the purge valve can be serviced with a kit of parts (about $35) and a few minutes under the rig.
It is basically a new valve, three bolts, with O Rings for a Bendix AD-9.
The 150 PSI seems high. Mine is barely to 120psi. Most are at 125PSI. Perhaps there is a gauge problem.
Thanks for the input I do not know about the pressure I guess it just never occurred to me that it could be too high. It has a gauge for the front and rear air both come up to 150 and have been that way all the time I have owned it. I will see if I have a service manual for the compressor and dryer. It is a bendix dryer I bought a service kit a couple of years ago and changed the media, oring and bleeder valve just as a PM issue. I don't think it will be too hard to get it straight just wanted all the info I could get going in.
2011 HHR Toad
deandec
Dean
95 CC Magna, Jeep GC
CT_WANDERER
Might be a check valve near the air drier and the drain valve that is leaking. Letting the air pressure fall requiring the air governor to turn the compressor back on too soon. Gary
Dog_Trainer
JR45 wrote:
x2 150lbs to high, should be around 120-125psi
JR
It has been 150 since I owned it 10 years ago
2011 HHR Toad
JR45
JR
2006 Country Coach Inspire 360 40ft Genoa Designer Series Cat C9 Samsung 197 RR
Aluminum Radiator was recently replaced with a STEEL & COPPER Bolt Together Radiator w/ updated rubber mountings
SilverLeaf VMS 330
Toad--2011 Ford Edge Sport, Air Force One
:C
Born_To_Travel
The spitter valve is activated when your air pressure peaks and the compressor shuts off.. Do you have a air leak that is causing the pump to kick on and off?.. Block the wheels and take the parking brake off and with the air pressure up do a walk around and listen for leaks..
dons2346
150 sounds a little high. Most run about 125 so you might want to take a look at the compressor governor.
When was the last time you serviced the dryer?
