Amount of water from washer
n4hwl
I have a splendide 2000s washer/dryer . Does anyone know how much water this thing uses on one normal wash? I got up this morning and found water in my shower. I did not know my wife had washed that much yesterday plus she thought I had left the gray valve open. Oh well. I think I have about a 60 or 70 gallon gray tank.
Thanks
Ken
2014 Tiffin Zephyr
7 REPLIES 7
John_Joey
Mine also uses water when it dries. Since it is not vented to the outside, cold water is used to condense the moisture then it is all pumped out.
There’s no fool, like an old fool.
2ndhom
bullydogs1 wrote:
On the full cotton setting, the thing could use up to 20 gallons..and if you use the extra rinse setting button, it could be up to 30...ask me how I know how...
X 2
Blaster_Man
Open the manual to page 9. The following are the amounts of water used for the first three items in each section:
Cotton, HD: 12, 7 1/2, 9.
Perm Press: 12, 12, 9.
Delicates: 16 1/2, 18, 15.
2014 American Eagle
bullydogs1
Stuart and Stella Denning
2016 Entegra Aspire 42RBQ
The 3 Bulldogs (Daisy, Sylvie and Stashie)
2018 Equinox Diesel (TOAD)
stuplich
Thanks
Ken
Ken,
My Splendide uses 10-12 gal. per average load.
However they can use 8 to 16 gal. per load, (depending upon the size of the loads, the wash/rinse cycles used, and the water pressure available in your coach).
Mel
'96 Safari
WyoTraveler
Leave the grey open when washing. Leave a little up and down loop in your sewer hose where it connects to the park fitting. Walk around the RV park and you will notice. Kind of a home made trap.
nelson
specs
2002 Damon Challenger 348 Ford V10
Blue Ox Auto Stop and Aventa II Tow Bar
2001 Ford Sport Trac with Remco Driveshaft Disconnect
