Antenna problems in Allegro 2013
struluv
We went on our first trip to San Diego last weekend, took our new 2013 Allegro 37' had a great time, was able to hook up to their cable (have been using our antenna when parked at home) now at home again, after hooking back up to the house (no cable just with the antenna) I can't get 1 channel. It seems like maybe the antenna isn't connected now. I can hear it turning, but i get nothing.
Is there maybe a plug that came loose driving home? Any help besides having to drive it to La Mirada would be greatly appreciated!
Sandra
11 REPLIES 11
dougrainer
fr8rplt wrote:
you might ask this question on www.tiffinrvnetwork.com. this is a Tiffin owners website with an unlimited amount of information.
True, but I AM a RV Technician at a Tiffin Dealership and have worked on Tiffins for 34 years, so the OP got the same advice that Tiffin or the Network would supply. Doug
wny_pat1
X-2!!! www.tiffinrvnetwork.com
โ€œAll journeys have secret destinations of which the traveler is unaware.โ€
fr8rplt
Tom & Bonnie
2010 Allegro Bus, Maroon Coral,PG Chassis
13 Lincoln MKX
Sir Finnegan (Golden Retreiver)
Mookie Blue (Toy Aussie Shepard)
Tinkerbell (Teapot Aussie Shepard)
Harleigh-The cat
In America anyone can be president and that is the chance you take!
Sooner_Schooner
Press the power booster button on your antenna if you have one.
2008 Damon Tuscany 4076 40' Diesel Pusher
struluv
Thanks everyone. I'm trying everything, but it still doesn't seem to work. I'm destine to drive to the dealership ๐Ÿ˜ž oh well, gotta get it taken care of, going back to Mission Bay RV park this weekend, definately need my TV.
Thank you again for all your input.
wa8yxm
You need to make sure your TV knows it is hooked to cable, This is normally a menu setting, In your RV there is either a wall plate with a switch, Light 12 volt outlet and antenna connection, Light must be on
A box of many buttons, Power must be on and ANT sellected
Or a Sensar Pro (Wall plate with 3 buttons, several lights, and two digital displays) which must be in any mote other than CABLE. Tap the top left button to check the mode it's in.
dougrainer
Tiffin uses the round antenna. You either have the hand held wired remote or the IR remote control. At the antenna hook up plate in the overhead above the dash right hand cabinet you MUST push the black button on that wall plate and the green lite will come on. You also MUST put each TV into Antenna(air) mode in each TV's set up. You have 2 choices---CABLE or Antenna. If you had Cable at the Campground then the TV's were set on Cable and you have to reset each TV to Antenna now and then do a channel programming. Inside your Tiffin owners packet should be a paper outlining what I just posted. Doug
gatorcq
TV setting. Goto menu and tell it you are on antenna and search for signals
Dale & Susan
DaGirls II Rv - Dakota & Tilly Traveling Companions.
2008 Alfa Gold, 2015 Ford F150 XLT
Roadmaster and Air Brake System
1600 Watts, Magnum Inv/Chg&Solar
800 Lithium Battery
DaGirslRV Blog
Dixiechick
Have you called Tiffin? They can help you.
Cathy and Don, finally retired :B
Cats-Whiskers the Princess and Shadow the Baby
2008 Allegro Class A Open Road 32'
Followin__the_s
Do you have a switchbox that needs to be switched back to antenna from cable?
fulltime55
Did you switch back to antenna on your TV or control box??
