Mar-02-2021 12:39 PM
Mar-03-2021 09:11 AM
time2roll wrote:theoldwizard1 wrote:To move liquid you would need to cool the tank to maybe -45 degrees maybe a little lower. OK it would move as a gas and condense into liquid in the very chilled tank.
The pressure in your tank varies with temperature. If you want to transfer the LP, you need different pressures. Cool the receiving tank in an ice water bath. If not practical, heat the full tank with hot water.
Dry ice at -78F would do the trick.
Mar-03-2021 08:45 AM
Mar-03-2021 07:41 AM
mowermech wrote:Done on the farm all the time. Need a tank that will supply liquid from near the bottom.
Many years ago I worked for the Forest Service burning logging slash piles. We used back-pack propane torches. When the torch bottle was empty, we returned to the pickup and filled the bottle from a 100 pound cylinder in the back of the truck. Liquid transferred from the big cylinder to the little bottle using only the pressure in the big cylinder. Of course, we had to open the "80% valve" on the little bottle to relieve the pressure so it would fill properly. As soon as we got liquid from the "80% valve" we shut off the valve on the big cylinder, shut off the valve on the little bottle, disconnected the hose, connected the torch and went back to lighting fires.
This long dissertation is just to illustrate that it IS possible to transfer liquid propane without a pump. Is it "safe"? Probably not. Anytime a flammable gas is vented to the atmosphere it can be dangerous.
Good luck.
Mar-03-2021 07:30 AM
CA Traveler wrote:mowermech wrote:Interesting post because every time a tank is filled from a "normal" station with a pump they open the small valve to determine when the tank is full. And some vapor/liquid escapes. So apparently it's a least a somewhat dangerous operation everytime a tank is filled.
Good luck.
Mar-03-2021 06:59 AM
Good luck.
Mar-03-2021 06:30 AM
Mar-03-2021 06:28 AM
Mar-03-2021 06:06 AM
Mar-03-2021 05:58 AM
pianotuna wrote:
You could add an extend-a-stay system and run from the smaller tanks.
Mar-03-2021 05:26 AM
Mar-03-2021 04:47 AM
Mar-03-2021 03:30 AM
MountainAir05 wrote:wanderingaimlessly wrote:
I'm not a specialist on this, but a question, Since many people run a portable grill from a low pressure line run from the RV system, Why , couldn't you attach a tank with a grill regulator to one of those fittings to basically back feed the system after turning off your main tank?
vapor and liquid.
Mar-03-2021 02:51 AM
Mar-02-2021 05:20 PM
Mar-02-2021 04:43 PM
wanderingaimlessly wrote:You can certainly run the RV like this and save what is in the RV propane tank.
