I have a 1979 Dodge Class B Okanagan camper . The dome lights will not come on. Tec says a short in wiring in panel wall. I require a manual for the electrical from rear battery to dome lights. Very costly to remove panels. Need advice.
"Forum Posting Help and Support is reserved for questions on how to post in the forums, signature and photo testing, reporting website or member account issues. Please avoid using Forum Posting Help and Support for RV related questions, as doing so can delay responses to your thread. Instead, create future threads in the RV FORUM which corresponds to the subject of your topic. Thank-you!"
there should be a switch on the light itself and could also have a wall switch or it could be burnt out bulbs or a blown fuse in the supply line. if it is a shorted out wire a new one may be able to be pulled through using the old one as a pull wire soldering a new wire to the old one and using it to pull it through the wall.
a lot of the older headlight switches had a position that when you turned the knob all the way to the left it turned on the dome lights. if your talking about a bad wire to the ceiling lights of the camper that will be tough to find you may have to try to run a new wire to them.
You aren't likely to find a manual for that unit, if one ever existed in the first place. A service manual for that year Dodge van might be of some use, or not.
