Anyone interested in 83 Pace Arrow Tear down and Rebuild?
fulltimin
Started to look into some water damage in the kitchen of our 83 Pace Arrow. The more I looked, the more I found. I have some pics of the damage so far. Anyone interested in following a rebuild thread?
If you want to do something, you will find a way.
If you don't, you will find an excuse.
Good judgement comes from experience.
A lot of experience, comes from bad judgement.
8,452 REPLIES 8,452
cruising_spud
Don't be so hasty to be critical. This forum has been so slow lately that fulltimin has been close to one of the top five posts for weeks.
Kathy
Johnny_G1
I have to agree with most poster's, it has been pretty boring for quite awhile, how bout's we get the show on the road????
98 Mountain Aire 34' 210 Cummins Puller and 2001 dodge dully with all the toy's, 400 + hp pullin a 2001 32.5' Okanogan 5th wheel, new to us after 5 yrs with the 28' Travel Aire. Lots of fun.
navegator
I think most of his time is just plain BS.
Baybe Sitting!
navegator
LouLawrence
DewLess wrote:
Well not complaining a big bunch, but I guess a bitโ€ฆ Can you kinda pickup the pace a bit, I am on the down side of like would to see the exterior started
You can think it, you just can't say it. OK, it's been 2 month and like 15 pages since he did anything more than apply a bit of fiberglass to a piece of wood so we are pretty much on track.
ro_sie
OMG! fulltimim. looks like some of your fan base is getting impatient. LOL
ro_sie
Art ( my roomie)
Fleetwood Revolution LE
DewLess
fulltimin
I wanted to post this a couple of days ago, but it just didn't happen.
I did get to add 3 layers of Epoxy over fiberglass cloth to make the joint much more stable.
This is for the drivers side skirting.
One step closer to getting that installed. Wahoo!
fulltimin
Next step was to fill in the gap area with some extra epoxy. I mixed up a very small batch and proceeded to fill it in.
I left the epoxy a little bit proud.
For the younger crowd, which probably haven't heard that term before ... It means to leave the epoxy stand out a little bit, or "higher" than the surrounding surfaces.
When that cures, I can then sand the excess off, so it is flush with the plywood. Then I can add the fiberglass cloth and epoxy to strengthen the joining of the 2 pieces of plywood.
fulltimin
I flipped the plywood today, since I had epoxy on 1 side only, so far.
I then sanded the area around where the 2 pieces joined, and made sure they were the same height, in order to get ready to epoxy this side also.
fulltimin
Then I proceeded to add a third coat to this side of the skirt.
fulltimin
Turns out the temps dropped somewhat and the epoxy was a little stiff, so it needed to be warmed up just a little bit.
fulltimin
I added my second coat of fiberglass cloth covered with epoxy over the seam between the 2 pieces of plywood for the left side skirt.
fulltimin
I also pulled out the left side skirt, because I need to add another piece to make it long enough. Adding this piece will lengthen it to about 20 feet long.
I used some fiberglass cloth, and epoxy, and applied the first coat today at the last joint. Typically, I'll use about 3 of these at the joint to hold things together.
Fortunately, epoxy will cure in a few hours and more than one coat can be applied in a day.
fulltimin
I have been wanting to finish off the roof at the back since last fall, and it just didn't happen.
I pulled out one of my trusses that I used to work on the roof and screwed it to the 2 saw horses so I can get up there and finish up the back area.
Now, if the weather co-operates I can get that buttoned up.
fulltimin
Well, it was a pretty good re-productive week.
Re-productive?
Does that mean you are making babies?
No.
Here's my twisted version.
When getting a good amount of work done, we call it a productive time, or maybe a productive week.
When some of the work has to be done over, in order to get it right, we call it ... yeah, re-productive.
Yeah, I know it's twisted and incorrect usage of the English language.
On the bright side, I did turn some of the mountains back into mole hills this week.
That means intermission is over. Yay!
