Jun-12-2019 07:25 PM
Jun-14-2019 10:25 AM
mikestock wrote:
My problem is that the control pad will not start. Brake on, transmission in neutral, motor running.
Jun-14-2019 10:07 AM
Jun-14-2019 09:41 AM
mikestock wrote:
I'm more than a little skeptical, but Leppert claims to have a replacement for the Atwood 80618 controller. I would need to replace the controller and the touch pad.
The person at Tiffin is Brent Bullard, who I hope to discuss this with before diving in. The price for the the controller and touch pad is $495.95, which would be much better than replacing the entire system.
Jun-14-2019 07:37 AM
Jun-14-2019 07:05 AM
Jun-14-2019 06:33 AM
mikestock wrote:haste maker wrote:
My Atwood jacks did the same thing as yours & my RV repair shop reset the system & now the panel lights up as it should & the shop said all the jacks work fine.
Where did you find someone to do this repair?
My problem is that the control pad will not come on. Brake on, transmission in neutral, motor running. I have acquired a lot of information on the system.
Trouble shooting procedure is to disconnect the + buss from the controller, unplug the Signal Wire Harness, waiting 10 minutes (didn't find out about the 10 minute wait until today), replacing the + buss, (most important) plug the Signal Wire Harness last. I think this is how they reset the system. While the connector was unplugged I confirmed 12 volts from the ignition switch when the ignition was on.
After all this, the "ON" switch still would not work.
I'm about to, sadly, conclude that the controller is bad. I was able to acquire one about 4 years ago when Atwood was in business. They have since been sold off to Dometic and then Leppert bought the leveler business from Dometic. My chances don't look good if the controller is, indeed, bad.
Jun-14-2019 05:31 AM
Jun-14-2019 05:25 AM
Jun-13-2019 06:15 PM
Jun-13-2019 02:04 PM
Jun-13-2019 05:06 AM
Jun-13-2019 05:02 AM
Jun-13-2019 03:24 AM
Jun-13-2019 03:05 AM
philandterri wrote:
I had Atwood Levelegs jacks on my motorhome, the control module went bad and we could not find a replacement. Dometic nor Lippert had any. Sent it to a company that repairs electronics, said it was not repairable. Salvage yards had one for several hundrad dollar with no guarantee. Tried Ebay and Amazon, no luck. Replaced the system with BigFoot Jacks.
Jun-13-2019 03:00 AM
