Follow up on this...I got to Magnum and we did a full diagnostic on it..all is as it should be with the system..then we did a start test while the gene was cold, right up...we noticed that during start up the voltage dips for a split microsecond into the 11's ..he suggested I check the 8 month old batteries to see if I had a bad cell...checked specific gravity..all of them in the green on the specific gravity device..I also had voltage setting at 12.1 or 12 rather than 12.2 which is the highest I can set for a voltage start...The temp sensor start works fine...batteries show good on the measuring device...if I am ever in this situation again, I will set to 12.2....my concern is the temp start for the bullies...life is too short to worry about this...especially the one time a year I'll be dry camping in NJ (RV and northern NJ don't mix) and if faced with this type of scenario again, just be mindful...Magnum suggested equalizing but didn't want to boil the batteries besides I have a de sulfator hooked up there..and the specific gravity in all cells showed good...Happy new Year to all..
Stuart and Stella Denning
2016 Entegra Aspire 42RBQ
The 3 Bulldogs (Daisy, Sylvie and Stashie)
2018 Equinox Diesel (TOAD)
