Awning strap replacement
beaubeau
Putting my awning away today and the strap broke right near the awning. Of course the awning slammed all the way up.
Any ideas how I can improvise a fix to finish out my trip?
Thx
Chip & Nancy (and our furry pack). 2008 Allegro Open Road Freightliner.
15 REPLIES 15
Taxman2004
Had to replace on and older class A. It was a 95 class A. I had to drill a hole in the slot to get the old one out and the new one in. If one broke the others will too. Buy enough for every awning and fix all at one time. Bought my replacements at Camping World.
Jim McManus
ata3001
One person on each arm to open or close it w/o a strap. Any camping supply/RV dealer will probably have replacements.
Ron & BJ
2008 Dutchmen Freedom Spirit FS180 w/full factory dark tinted glass. (9 .yrs w/o any issues)
2014 Chevy Silverado LT Dbl cab, 5.3 L, 4 WD, tow pkg, max payload pkg, Prodigy
Tom_N
Camping World sells replacement straps.
Sarver, PA/Crystal River, FL/Shelocta, PA ยท W3TLN ยท FMCA 335149 ยท Mystic Knights of the Sea
2005 Suncruiser 38R ยท W24 chassis, no chassis mods needed ยท 2013 Honda Accord EX-L ยท 2008 Honda Odyssey EX-L
rockhillmanor
If you are at a CG they most likely will have those for sale in the office.
DutchmenSport
Or, go to any RV dealership that has a parts store and pick up a new awning strap. They just slide in the groove of your awning. Simple to replace, cost about $6.00 or less.
DSDP_Don
Do as "Tom/Barb" suggested above and then fix it the old fashion way. Remove the strap and hand sew it back together. It will get you through the trip.
The awning strap just slides into a round slot. If you can't repair the old piece find a 2" - 3" piece of hard plastic tubing or metal tubing that fits in the slot. Run a piece of cord through the tubing, creating about a 5' loop and slide it into the slot. It will work until you get home.
Don & Mary
2019 Newmar Dutch Star 4018 - All Electric
2019 Ford Raptor Crew Cab
Tom_Barb
Johno02 wrote:
Google ToughTops.
they will still have to replace the strap.:)
2000 Newmar mountain aire 4081 DP, ISC/350 Allison 6 speed, Wrangler JL toad.
Tom_Barb
I believe they were asking how to open it with out the strap, and that is, unlock it, pull it down by the arms requires two people. after you get it deployed like normal. you'll find there is a slot, that the strap slides into and out of , slide the old broken piece out, then reverse the process to install the new strap.
Johno02
Google ToughTops.
Noel and Betty Johnson (and Harry)
2005 GulfStream Ultra Supreme, 1 Old grouch, 1 wonderful wife, and two silly poodles.
beaubeau
Thanks for all this help. Also, we had been starting to think about replacing the fabric - might make sense to do it in the same service call / visit.
Any idea about the cost to replace awning fabric?
RognBon
If the awning is closed, just lock it and then replace the strap after you finish your trip.
RognBon
1997 Monaco Dynasty 40'
Cummins 8.3 325 HP
2008 Ford Edge Toad
doxiemom11
They are also available online if you will be somewhere for a few days where you can have the delivery made.
Tom_N
Years ago I sewed one back together.
rgatijnet1
If you are anywhere near an RV supply store, most of them have replacement straps in stock and can probably help you replace it.
