โAug-29-2020 10:37 AM
โAug-31-2020 04:04 PM
โAug-31-2020 02:09 PM
SGTJOE wrote:
I've had the MH plugged into 50amp at my house since mid Dec. Do you think this might be why I have corrosion on the main positive cable, but not on the battery terminal?
โAug-31-2020 11:58 AM
โAug-30-2020 03:43 PM
โAug-30-2020 03:08 PM
SGTJOE wrote:
I have the system that replaces the battery cell caps so I can fill my batteries by pumping water into the batteries, anyone remember the name of that system? I need to replace the pump that transfers the water from the container through one of the hoses .
โAug-30-2020 01:48 PM
โAug-30-2020 01:37 PM
โAug-29-2020 07:56 PM
time2roll wrote:
Simple. Some acid got in the connection.
You can clean it up or just replace it. Use heat shrink to seal the insulation to the lug.
Otherwise a picture might help.
http://photoposting.is-great.net/?i=1
โAug-29-2020 07:28 PM
โAug-29-2020 06:27 PM
theoldwizard1 wrote:RLS7201 wrote:
If your charge algorithm is correct and the batteries are not overfilled you will not have corrosion problems.
My 50+ years under the hood of cars disagrees with you.
โAug-29-2020 02:09 PM
โAug-29-2020 11:24 AM
โAug-29-2020 11:11 AM
SGTJOE wrote:
My hot lead to my 6v batteries (1 of 4) has battery corrosion on the wire just before the hook up clamp. This is the primary positive cable that supports the 4 Duracell GC2 Golf Cart Batteries. Any thoughts as to why this happened?
