battery charging
Tom_Barb
how long should we stay on Float charging before change. ??
We are now about 3 months of no change.
13.3 Volts steady
Should I disconnect for a while, and allow the batteries to disconnect for a while.
2000 Newmar mountain aire 4081 DP, ISC/350 Allison 6 speed, Wrangler JL toad.
5 REPLIES 5
Sam_Spade
Some "tenders" turn off and on but most just drop down to the float level, which is what yours has done, and stay there more or less forever.
'07 Damon Outlaw 3611
CanAm Spyder in the "trunk"
pianotuna
Nomad III
Nomad III
There is some evidence that cycling helps batteries last longer. I'd suggest that one day per week you run from the battery bank.
Regards, Don
time2roll
Will not hurt to run overnight on battery power once every 30 to 90 days.
IMO a few cycles now and then is fine and proves what is working.
ScottG
13.2~13.3 is good forever. You can forget about it!
I will check my water levels in the spring and very little, if any, will be needed.
S
Ed_Gee
Float charge at that voltage should be fine......but if a wet cell just check the water level occasionally.
Ed - on the Central Oregon coast
2018 Winnebago Fuse 23A
Scion xA toad
