Battery disconnect and charging
Devoredude
I have two battery disconnect switches on my 07 terra, one for the chassis, one for the pair of 6 v coach batteries. I always turn these off when parked. I am connected to shore power and was wondering if this charges my coach batteries with the switch off?
Thanks and happy new year!
07 Terra LX 31M Workhorse - Allison 6 spd
Honda CRF450R (FI)
Honda XR650R (Plated)
Yamaha 06 Rhino (wife)
Yamaha TTR125 (son)
Honda Rancher 4X Quad
1971 Bronco, 302, NP435, Lockers, etc.
7 REPLIES 7
Devoredude
Thanks, switch (s) must be on.
I put a volmeter across my 6V coach batts, read 13V (we just got back from a desert trip so they are fully charged). Plugged in, same voltage, 13. Flipped switch and it reads 13.5. Also, the engine battery switch needs to be on to charge the engine battery which make sense.
Happy New Year All!
Honda CRF450R (FI)
Yamaha TTR125 (son)
OnaQuest
On a Terra, with the factory installed converter, your batteries will NOT charge with the disconnect switches OFF.
RVUSA
Depending on what came with it (convertor vs. invertor/charger), you could be shortening the life of your 12V stuff by not leaving the house batteries in.
The converter can have a pretty high voltage on it without the batteries switched in and that high voltage can burn up lamps pretty quickly.
Triker33
With switch off. Put a tester on the batteries to see how many volts they have.
If 13V plus then the charger is charging them.
If only around 12.4V then charger is not.
Turn switch on and there should be 13 + again.
Larry Full Time Since 99
1999 34Q Discovery DP ISB 275HP 6 Speed Allison
VMSpc | Pressure Pro
14 Lincoln MKS EcoBoost Toad
Click here to see where I am
JimM68
I'm with Joe. It just depends on how they wired it up.
On ours they kill almost everything, but there are a couple small wires directly on the batteries that still have power, smoke and propane detectors, engine and transmission computers, radio memory, stuff like that.
Jim M.
2008 Monaco Knight 40skq, moho #2
The "68"
My very own new forumfirstgens.com
My new blog
crappie_fisherm
I do not think there is one right answer to this question.
On my coach...my inverter is wired directly to the batteries since I have a residential refrigerator...
Flipping the battery disconnect switch does NOT turn off my fridge since my fridge gets powered from the inverter which is making AC from the house batteries...so for my setup...having the battery disconnects disconnected and my AC cord plugged in would still charge my batteries...
It all depends on how your inverter/charger is wired.
When you flip the disconnect switches...does that kill your inverter?...I would assume it would IF your inverter is on the opposite side of the switch from the batteries...
Like I said...on mine...when I flip the switches OFF to disconnect the batteries...my fridge will STILL work and my inverter/charger STILL has power going to it...so I know which side of the switch my inverter/charger is.
Good luck,
joe.
2007 Tiffin Phaeton 40 QSH 350Cat (3 women and 4 slides...Just RIGHT! :B)
2012 Jeep Liberty Sport (toad)
2005 Ford Excursion V10 w/4.30's (Sold)
wildtoad
Typically NOT. The switches are designed to totally isolate the batteries so there is no potential for drain. I've been told several times that for the system to charge the batteries they must be switched on.
Tom Wilds
Blythewood, SC
2015 Jeep Wrangler 2dr HT
