Battery Problems
Jabrad_s_Papa
My 2006 Damen Daybreak battery is losing complete power fast. I put in a new battery, it died. Took it back, they checked it and said it was OK. Then recharged it. Worked fine for 2 days now is completely dead again.
I'm not sure what would be a draw to kill it so fast.
I noticed a few weeks ago the bedroom slide wouldn't come out unless I had the generator on. It never worked that way before. It always worked with the battery only.
When it ran with newly charged battery it ran great. Then within minutes it's dead.
Your thoughts please.Thanks, Gary
7 REPLIES 7
ArchHoagland
Thanks for the update, glad to hear all is well!
2004 Monaco La Palma 36DBD
Workhorse W22 8.1 Gas Allison 1000, 7.1 mpg
2000 LEXUS RX300 FWD 22MPG 4020 LBS
US Gear Brakes
Jabrad_s_Papa
Thanks everyone It turned out to be the alternator. Replaced it and all is good.
Jabrad_s_Papa
Great ideas. I will check each one Thanks
Argosy24
House or chassis battery?
A small light can kill a battery in 2 days. Mine seems to have a light if it has a door, have you checked to make sure everything is off, including bays? Ignition switch off completely?
If it's nothing that obvious a DVM that checks amps can be used. It needs to be inline in the circuit, that makes the fuse block the best choice. Once you find the right circuit it's a matter of eliminating components.
garym114
Get a digital multimeter too see 12v systems are failing.
2000 Sea Breeze F53 V10 - CR-V Toad
Some RV batteries live a long and useful life, some are murdered.
Get a Digital Multimeter and Learn How to Use It
stripit
I would start pulling fuses and see what might be drawing all the power, using a meter or at least a test light to find the problem would be where i would start.
Stacey Frank
2016 Tiffin Allegro Bus 40AP
2019 Tesla Model X
2015 Cadillac SRX we Tow
1991 Avanti Convertible
Ed_Gee
Whatever is supposed to charge your battery is not working correctly. Look in that direction....
Ed - on the Central Oregon coast
2018 Winnebago Fuse 23A
Scion xA toad
