Belts replacement
rmel
Hi, does anyone have step by step instructions on how to replace engine belts / pulles on Fleetwood Bounder 1990, Oshkosh chassis 460 cid?
Thanks!
9 REPLIES 9
BobR
My 1991 Ford has a belt tensioner on the front belt. The other belt is adjusted by moving the alternator. My squeek turned out to be front belt and not a pulley. I simply removed the first belt and started engine. No noise, replaced belt and still no noise. I really thought it pulley bearings, so go step by step.
Yankee_Clipper
I've had to replace the idler pulley twice. Both times the bearings were shot and causing the squeal you report.
Yankee Clipper
2014 Winnebago Sightseer 33C on Ford F53 6.8l V10
2014 Honda CRV 4 down toad/Roadmaster Falcon2 with EvenBrake
TireMinder TPMS,Tiger, the Little Big Man minidachshund,
Rosey the minidachshund resident Princess-in-Chief
mlslcan
The 1990 era 460 does not have automatic belt tension pulleys. It should have two belts and the adjustment is on the alternator and AC compressor. At least it was on my last RV on the Ford F53 chassis. It might be different on the Oshkosh chassis but I had an old thunderbird with the 460 and it was also the alternator and AC. On mine I changed them from above with the exception that I crawled underneath to verify that the belts were in the correct groves on the harmonic balancer before giving the final tightening and starting the engine.
Mike
crasster
time2roll wrote:
In the old days we would just bump them off with a screwdriver and new belt back on with same ๐Ÿ˜‰
You made me feel old. ๐Ÿ™‚ 1990 may not have a tensioner. In this case it may tighten with the alternator. Should be pretty straight forward really.
4 whopping cylinders on Toyota RV's. Talk about great getting good MPG. Also I have a very light foot on the pedal. I followed some MPG advice on Livingpress.com and I now get 22 MPG! Not bad for a home on wheels.
Tinstar
It sounds like a loose belt since it's doing it during acceleration. Does it stop squealing after leveling out your speed? If so, get some belt dressing at your auto store and spray it on the belts OR take a bar of soap and rub it on the belt/s. If that stops the squealing, it the belt, if not it could be the pulley. The belt might just need to be tightened or the belt could be bad.
:CNever pass up a chance to go somewhere:C
time2roll
rmel
Getting squiken sound on acceleration, not sure if its pulley or belt needs to be replaced. Anyone knows what is the best way to get to the belts? Is it from inside the coach, or front of the engine? Per manual the engine has pulley tensioners.
Tinstar
What pulley/s are you wanting to replace? There may be 4 or 5 of them. Some are mounted on a idler arm and others have a center bolt.
lanerd
Does it have belt tensioners? If yes, just remove old belts and install new ones. The tensioner will move to allow removal and reinstall.
If no, then you'll have to find the accessory that has an adjustable mounting arm (alternator, AC compressor, etc) and loosen the bolt to slide the accessory item inward to release the tension on the belt. Then remove and replace and re-tension the accessory so the belt has about a 1" play in the center.
If you can get to them, it's not a difficult job. However, typically that available room to work is very limited and this makes the job harder.
Ron & Sandie
2013 Tiffin Phaeton 42LH Cummins ISL 400hp
Toad: 2011 GMC Terrain SLT2
Tow Bar: Sterling AT
Toad Brakes: Unified by U.S. Gear
TPMS: Pressure Pro
Member of: GS, FMCA, Allegro
RETIRED!! How sweet it is....
