Best caulk for fiberglass roof?
Ro646a
Can anyone advise me on the best caulking to use on my fiberglass roof?
I want to real the joint where the front cap meets the curve at the sides of the roof.
Roland
1999 American Dream 40 DVS
2011 Jeep Liberty
Roadmaster Sterling Towbar
Brake Buddy
7 REPLIES 7
Snomas
Decor sealant or eternabond. I use both. eternabond is an excellent product that adheres well if installed properly. Check their website for installation video. Then you can choose the best way for you.
2006 WINNEBAGO ASPECT 29H Ford E450 Super Duty
2018 F150 Lariat Crew Cab, Coyote 5.0 L RWD
msmith1199
This is a thread on how I re-did my front seam: Enternabond Tape on the front seam
2021 Nexus Viper 27V. Class B+
2019 Ford Ranger 4x4
msmith1199
jplante4 wrote:
Both. Clean the seam of old caulk, seal the seam with Eternabond, feather the edges and seal with Dicor.
This is what I did with a couple of exceptions. I completely took the seam apart and removed the old screws. I think put new screws and used some pieces of oak inside on the back of the roof to give the screws something to eat in to. I couldn't get to the entire seam from the bottom, but I got to about four feet of the center. Then before putting the Eternabond tape on. I sealed the seam with Dicor, being careful not to over do it. The ertnabond won't stick to the Dicor so I made sure just to seal under the seam and leave the fiberglass explosed. Been working for two years now with no leaks. I posted photos on here, I'll try and find them and post the links.
jplante4
Jerry & Jeanne
1996 Safari Sahara 3530 - 'White Tiger'
CAT 3126/Allison 6 speed/Magnum Chassis
2014 Equinox AWD / Blue Ox
olfarmer
10forty2 wrote:
Dicor Lap Sealant. Self leveling for flat surfaces and Non-Sag for the vertical surfaces.
I second Dicor Lap Sealant. I have had very good luck with it. ๐Ÿ™‚
Ed & Ruby & the 2 cats
2001 Winnebago Brave 30W
7.4 gas Work Horse Chassis
99 Jeep Grand Cherokee
10forty2
1999 Holiday Rambler Endeavor, 36' Gasser
Triton V10, Ford F53 Chassis
gbopp
Use Eternabond tape if possible. It will last much longer than caulk.
