โOct-31-2017 12:09 PM
โNov-01-2017 08:42 AM
โNov-01-2017 06:21 AM
lj2654 wrote:
I have a 40' Beaver DP with air over hydraulic brakes and picking it up tomorrow after having all new front brake rotors, wheel seals, pads, calipers, brake fluid flush and bleed. New oil bath hubs and seals and new gear oil. The parts and labor is about $1700 for mine.
โNov-01-2017 05:08 AM
lrquil wrote:
It's a 2002 National (Marlin) 300 Cummins w/a Spartan chassis. 89,400 miles. Not sure what the cut-in and cut-out pressure is. This is our 6th motorhome in 20 years, all but one had air brakes. We have had tire issues over the years but never a problem with brakes.
โNov-01-2017 02:34 AM
FormerBoater wrote:
Your unit with a Spartan chassis has automatic slack adjusters.
They need to be calibrated periodically which is done from the driver's seat.
This involves fully stroking your brake pedal for 30 seconds or so, repeat 5 times.
Roll down your window, if you hear a clicking sound then your slacks are adjusting to restore your full braking power.
Often overlooked, simple to do and does not cost you a dime!
Videos are available on the web.
I would try this first.
โOct-31-2017 10:46 PM
โOct-31-2017 09:55 PM
โOct-31-2017 08:47 PM
โOct-31-2017 08:29 PM
lrquil wrote:
Coach stops OK, but takes heavy foot pressure. Not sure if this is an air problem or if I need brakes. Anyone know what a brake job costs on a class A diesel?
โOct-31-2017 08:02 PM
โOct-31-2017 05:08 PM
RedRollingRoadblock wrote:gutfelt wrote:
he did say air brakes I doubt its leaking oil seal
So his bearings run with air for lubrication?
โOct-31-2017 04:49 PM
โOct-31-2017 03:59 PM
โOct-31-2017 03:46 PM
โOct-31-2017 03:23 PM
