โJul-21-2018 10:00 PM
โJul-22-2018 10:03 AM
โJul-22-2018 08:58 AM
Woodwharf wrote:
Thank you for the replies so far. The tail light assemblies on my motorhome were cracked and faded being its an 83. And the bulbs themselves were not grounding anymore so I had to replace the entire brake light/taillight assembly. And on my coach the brake and turn signal are red. But on my motorhome there are 5 wires for each side of the brake/ tail lights. 3 whites a black and yellow and green for each side.
โJul-22-2018 08:49 AM
โJul-22-2018 07:29 AM
โJul-22-2018 05:49 AM
โJul-22-2018 05:42 AM
โJul-21-2018 10:41 PM
Woodwharf wrote:
Hi I recently have had to install new brake lights on my 1983 fleetwood southwind Motorhome and I'm having trouble figuring out what the different colored wires are. I know the yellow wire on driver side and green wire on passenger side are for the turn signal and I'm assuming the black wire on each side is ground. But I also have 3 white wires. And that's where I'm getting confused. One of the white wires is thicker gauge then the other two. Could this thicker gauge white wire be for the brake light itself? Or is this the reverse light? When my friend is following me she says the light are dim and hard to see in the daylight. So if anyone has any input on this I would greatly appreciate. Thank you in advance.
