โMay-07-2012 04:12 PM
โJun-04-2021 08:37 AM
eldel wrote:
Got the right hand side of the 28a just about done. Once we get the final positioning of the table (folded down in this picture) sorted out then we finish the electrics and the dinette goes and is replaced by work area and cupboards. Oh - and the wine rack ๐
โJun-04-2021 07:34 AM
SJ-Chris wrote:
Gray/Black waste tank upgrade???
I have two 2015 Thor Majestic 28a units purchased from Cruise America.
I've made many upgrades and find them to be well built/maintained.
One thing I wish was different is the waste water storage tank capacities. I believe they are about 25 gallons each (black/gray). With just a few people camping they fill up pretty quick. Has anyone upgraded these to larger capacities? Just curious if that is something easily doable and if anyone had any experience to share on the subject.
Thanks!
-Chris
โJun-02-2021 04:18 PM
โJun-01-2021 11:07 AM
โMay-31-2021 05:23 PM
Pepi's_Mom wrote:
Well golly. I just finished reading all 154 pages and many, if not most, of my questions have been answered. I've truly enjoyed reading about all the fixes and changes and whatnot. Thanks to all for the info.
My husband and I are seriously considering the Majestic 28a. We would like to go talk to someone and considered going to Newark on Friday. Then I remembered the holiday. We'll wait. I would guess that they would be too busy.
I have several questions that deal with the bedroom. We're full timers and have two cats and a dog. Pepi, the dog, is a dachshund/beagle mix. Short legs. Any suggestions to make it easier for her to get on the bed? I figure I'll have a better idea of what I can do once I get a better look. I'll probably have to build something.
Also, is there any way to make a cat-sized opening for access from the bedroom to the rear storage? Keeping the litterboxes in the storage bay would be so much nicer.
Thanks in advance.
โMay-31-2021 04:29 PM
โMay-31-2021 02:56 AM
โMay-29-2021 02:04 PM
Booner wrote:
I can't speak exactly about the unit you're buying, as mine is the smaller 23A.
I'm going to assume your problems with mounting a TV in the bedroom area will be these two; routing a cable for an antenna and powering the TV. mounting the TV shouldn't be a problem, a flat screen isn't that heavy depending on the size. If you mount it under an overhead cabinet, for example, you could tap into a light fixture for 12 volts. If you get a TV that runs on 110 volts, you'll have to either be on shore power or the generator to run the TV. So buy a TV that runs on 12 volts and you'll bypass that problem. (TV's that run on 110 volts have a transformer in them to convert it to 12 volts anyway).
I will assume you'll have an antenna on the roof, which means you'll have to add that. You'll have to run an coax cable from that antenna to the TV, and you'll probably want to power that coax to amplify the signal so you'll need power for that (12v). The roof vent for the refrigerator will give you a path from the roof down to underneath the unit so that's a good way to run the coax. From underneath the unit you can go into the storage area and then up to the bed.
A bedroom TV can be done, but you'll need a antenna that rotates to get a signal and you have to be within 50ish miles from the TV transmitter or stay in campgrounds that have cable available. If all you be using the TV for is to watch DVD's, then the installation will be much simpler.
Or, you could get a tablet that operates on 4g and then anywhere you get a cell signal you'll have entertainment from anywhere in or out of the TV. It's what I do.
โMay-29-2021 12:25 AM
โMay-26-2021 03:40 PM
โMay-26-2021 09:53 AM
โMay-25-2021 08:08 PM
Thanks in advance.
โMay-25-2021 07:45 PM
Thanks in advance.
โMay-25-2021 06:40 PM
โMay-25-2021 01:41 PM
