โMay-07-2012 04:12 PM
โDec-24-2020 11:36 AM
โDec-24-2020 10:38 AM
โDec-24-2020 09:27 AM
Majestic31 wrote:
I purchased a four winds Majestic 2011 28a last year, 120.000 miles on it I had to replace all of the tires, all new Bilstein shocks.rear camera,TV mount, 3 Vent covers, Roadmaster Reflex Steering Stabilizer Best addition so far, Sumo Springs bump stops Rear HEAVY DUTY, Front regular, Wheel alignment Looking to buy Sumo springs heavy duty rear fake air bag to try to stop the heavy bang in rear going over bumps, water empty rv unloaded still bangs going over bumps Sumo bump stops helped 50%,New passenger side mirror,Water filter system, Screen door bar, All new valve stems,
โDec-23-2020 05:04 AM
IAMICHABOD wrote:socal77 wrote:
Hi Gang,
I'm up in Pismo with my 2009 28A for a couple days. Went to turn on the heater tonight and will not turn on. I think I hear a "click" but the blower doesn't kick on. My propane indicator says 2/3 full and the stove burners work fine. Any troubleshooting suggestions?
I just saw your post,as you know I don't have the same RV but I would first check and see if your batteries are up and they have a good connection to the furnace,the blower runs on 12 volt.
My next suggestion would be to post this in the Tech Section and ask there,include your make and model of the furnace,I am sure someone will come along with some help.
Good Luck and I hope the rest of the trip will go well.
โDec-22-2020 09:57 AM
socal77 wrote:
Hi Gang,
โDec-21-2020 07:49 PM
โDec-13-2020 08:12 AM
IAMICHABOD wrote:
:B The subject comes up quite often here On The Forum
โDec-13-2020 07:53 AM
Booner wrote:
Got Dust?
Since I purchased my former rental, I spend a lot of time on this and other forums trying to learn from others; what problems they have and how they fixed them. I've come to the conclusion that I did the right thing in buying my first RV from CA. Reading the problems buyers have had with their "factory new" motorhomes, people who've spent 3 times what I spent and still have major issues with their new motorhome, only confirms that my decision was the right one.
โDec-13-2020 07:42 AM
IAMICHABOD wrote:
Looking at the picture there seems to be screws in the lower plate,maybe unscrew them and look under it.Inquiring minds want to know...:B
โDec-13-2020 07:28 AM
SJ-Chris wrote:Booner wrote:MtnBikeMarty wrote:quasimatter wrote:
Thanks Chris for the above answers - Makes sense - I will plan on getting 2 identical batteries.
Another quick question for Majestic 28A owners, What is the compartment in front of Master Bed - It is solid metal box with metal cover screwed on with special pin-in Hex screws. I opened it up and voila - there is nothing in there. Was it supposed to house something? Attaching a picture.
As you can see - there is another metal box inside with sides open (nothing inside that either). Maybe it used to house something which was removed (or an option that was not installed)? It looks a bit odd being right at the foot of the bed and also just being big metal plate which does not match other flooring.
PS: Is there a forum anywhere that is specific to Majestic (or even 28A)?
I remember asking my CA salesman, and he said something about it was an access panel to the transmission, maybe the differential. I just took it at that and never opened it up. Maybe someone else has better information. MtnBikeMarty
I don't know if that access hatch is the same in my unit (23A) as your larger unit, but I was told it was an access panel for the fuel pump.
Enjoy your new toy!
Booner
I was told also that it is access to the fuel pump in the event it needs to be changed. Made me think, "Gee, how often does the fuel pump have to go out such that they design a floor panel like that?"...
-Chris
โDec-13-2020 06:35 AM
โDec-13-2020 12:55 AM
Enjoy your new toy!
Booner
โDec-11-2020 04:31 PM
โDec-11-2020 09:32 AM
โDec-11-2020 09:11 AM
