โNov-12-2014 07:23 AM
โNov-18-2014 09:54 AM
โNov-18-2014 07:22 AM
pnichols wrote:My most extreme leveling was in Big Basin SP which took several attempts.CA Traveler wrote:
MH leveling should not be difficult. In the past I would pull in, look at the levers, place my leveling blocks, drive up and be level. While I agree it takes a few trials on the other hand it's not rocket science, just know your rig.
It's not quite that easy in places like this:
โNov-18-2014 04:13 AM
IAMICHABOD wrote:EMD360 wrote:
Personally, I like the tri-levelers.
We can use just the two of them instead of building up the block pyramids
I have to agree with EMD360. I have used the wood ones that other people here talked about and found them heavy and unwieldy, the plastic Lego type were a pain to put together and would often break.
The Tri-Levelers that came with my Ex Rental have worked every where that I have needed them with out fail and if a Rental Company uses them as their standard Leveling Device that are in each Rental then they must stand up to most any kind of use.
They even show them in their Orientation Video with a full demonstration of their use at the 11 minute mark in the video.
โNov-17-2014 08:32 PM
โNov-17-2014 06:07 PM
โNov-17-2014 05:52 PM
โNov-17-2014 09:06 AM
โNov-16-2014 08:17 AM
โNov-16-2014 07:58 AM
โNov-16-2014 07:39 AM
โNov-16-2014 07:11 AM
pnichols wrote:pianotuna wrote:
No, I've never needed to do both rear duals on passenger's and driver's side.
Don ... then how do you raise the whole back end when it's low? It's of course a tremendous tire overload to support only one tire of a dual set on a motorhome when leveling.
โNov-16-2014 05:33 AM
โNov-16-2014 05:05 AM
โNov-15-2014 09:09 AM
