โJan-20-2017 03:56 AM
โJan-25-2017 02:47 AM
howdy35 wrote:Bingo! Both the OP and his step father seem to have the knowledge to either do this, or just replace the sketchy breaker on the circuit he's plugging into. Landlord won't know the difference.
Why don't you and this "Pro" electrician just go to the box and put in an accessory 30 amp RV outlet. Problem solved and it will not cost much money. I have done that at least 3 times at my kids house. Lowes has all the parts.
This will help everyone feel better about the situation and you can run pretty much what you need to run. Good luck with your situation.
โJan-25-2017 02:25 AM
โJan-25-2017 12:22 AM
โJan-21-2017 04:53 PM
AllegroD wrote:86CoachmanR wrote:
I have the 30A RV Dogtail plugged into a 30A RV extension cord, plugged into a 120V 15A dogbone RV extension, and am about to plug that into the 15A wall socket in the house. All good???
Yes.
โJan-21-2017 04:48 PM
โJan-21-2017 01:55 PM
โJan-21-2017 11:17 AM
86CoachmanR wrote:AllegroD wrote:
As other have said, you can do this but there is a risk of using too much and causing a brown out. What that does is is when voltage drops below 105 volts. Some things are not affected by that low voltage, like a space heater. Many appliances are. Extension cords and hockey puck adapters can be affected. They can over heat and cause fires.
I would get a Kill-A-Watt and not go below 105 volts.
Yea, I've read that too, however I'm opting out of using the electrical heater, and will only be interested the RV when I need to use the computer or feel like using the game console, and as far as sleeping goes, well, I have lots of blankets. So far with just the monitor, one overhead light and the console running at the same time it comes to 2.96amps so estimated 5amps maybe 6amps max to account for trickle charge and other background "parasite" components. Would that cause a dip in voltage? I'm trying to keep the distance as low as possible. To get the most voltage pushed.
โJan-21-2017 07:24 AM
Canadian Rainbirds wrote:tropical36 wrote:
I think for making everyone happy in a hurry, I would just get myself and inline box with a single pole 15 or 20 amp breaker installed or make it up yourself and then plug this into the outlet.
Best suggestion yet. In fact, since your load is so low, you could use a 10A breaker.
โJan-21-2017 07:08 AM
โJan-21-2017 06:57 AM
86CoachmanR wrote:DrewE wrote:pianotuna wrote:
Hi,
It is best to add up all the items and keep the wattage below 1440 on a single 15 amp circuit. I can't imagine the loads you want to run being more than about 800 watts. That would include 325 watts for the fridge.
30 amps should trip the breaker. It would be easy to test that by deliberately turning on items.
In general, testing a breaker this way should be okay.
In the particular case of FPE stab-loc breakers, this is not a wise idea at all. Repeated use is one of the things that causes them to fail (apparently the contacts tend to weld themselves together or something similar). The recommendations I've seen have been to not test them and even to avoid cycling them manually. At least sometimes when damaged, the handles on the breakers are not a good indication of whether they're closed or not--the handle can be off, but the electricity still connected.
I must say I'm glad I don't have to deal with an FPE panel in my house.
Yea, I can't believe this house has FPE still, my mother says she thinks the property owner has the inspector in his pocket because it's been inspected and they "pass" it.
โJan-21-2017 06:55 AM
โJan-21-2017 04:58 AM
86CoachmanR wrote:crcr wrote:86CoachmanR wrote:crcr wrote:
We've safely done it many times in our RV driveway next to the house when cleaning up or loading up our TT. The 15/20 amp circuit has no problem running the AC, though once DW started running the vacuum cleaner while the AC was on and tripped the circuit breaker. I asked her not to run anything else when the AC is on.
Just be smart, as someone said, don't use an electric space heater, use your built in propane heater for heat. And if running the AC, don't run anything else extra at the same time.
Also, do NOT use a household or even a construction type extension cord. Go from the RV power cord to the dogleg adapter to the 120V outlet. If you need an extension cord to reach power, buy an RV extension cord. I always carry one of those in the RV anyway.
Everything ive read so far says that a 10G extension cord is more than sufficient, ive never read anything about an RV Specific cord. Im just curious as to the difference, I can google it but would rather get your personal experience on the matter. Also, If the space heater i running at half of max 1500W power, is that really an issue? Im just trying to wrap my head around the details as the wiring diagrams included with the RV are a bit out of my league of understanding. Thanks again for the fast replies!!
Here are several 30 amp RV extension cords on Amazon. CLICKY
They are the same heavy gauge as your RV power cord, and have the same 30 amp male and female ends.
Only problem is that where the driveway is and my dogtail is this extension won't reach the power outlet, it's hard to find the 30amp female to 15amp male extension cord longer than a foot or two, I need approximately 6 to 8 more foot of wire to reach the outlet. I'm having rouble finding an RV extension that long :h
โJan-20-2017 07:11 PM
Hi,
โJan-20-2017 07:04 PM
pianotuna wrote:
Hi,
