Jan-20-2017 03:56 AM
Jan-20-2017 09:09 AM
86CoachmanR wrote:
****** UPDATE TO SITUATION *****
I was just informed that the circuit breaker is an outdated out of code Federal Pacific Energy board, which, the landlord refuses to update. The concern is that, with these breakers known to be 1 out of 4 faulty, that the breaker wouldn't trip causing a fire...However they've been in this house for 13 years, and have used the 30A dryer on a 20A circuit...Proving my point that the RV would barely use any energy compared to that dryer...It's difficult using facts and logic to prove a point to the paranoid.
Jan-20-2017 08:44 AM
coolmom42 wrote:86CoachmanR wrote:Terryallan wrote:
Yes you can with no problems. Should your MH call for more amp than the circuit is rated for. It will trip the breaker. No harm, no foul. Folks. It really is that easy.
Exactly my point, however the person in question is a paranoid type and is thinking fire is inevitable.
Sounds to me he is not a person I would want to live in close proximity with for very long. In your shoes I would be looking hard for somewhere else to park.
Jan-20-2017 08:41 AM
coolmom42 wrote:86CoachmanR wrote:coolmom42 wrote:86CoachmanR wrote:rgatijnet1 wrote:
I have a 50 amp coach and when visiting some friends I have to plug in to their 15/20 amp circuit. This allows us to run one AC unit/or electric heater and our lights and TV. If we need to run the microwave, I turn off the AC for a few minutes. I also put the water heater on propane as well as the refrigerator and make sure that my inverter/charger is set to low charge.
Since you are just using an adapter the draw of a heater will not cause your 30 amp power cord to overheat, as you found out with three weeks at your other location.
Thanks, this is what i figured, owning an RV necessitates that one understands basic and intermediate electrical theory and math, and the relative at hand is an Electrician, and I am sure that his professional knowledge is making him paranoid to the worst case scenario.
NEVER let this person do any wiring for you. He clearly doesn't understand how current works.
who? rgatijnet1? or the family member in question? Im guessing the latter?
The latter. Who is supposed to be an electrician.
Jan-20-2017 08:39 AM
Jan-20-2017 08:30 AM
NCWriter wrote:
If I had a relative who was giving me what I considered to be invalid reasons they did not want me to plug in, I might wonder if their preference actually is not having a relative living in a class A RV in my driveway.
Jan-20-2017 08:28 AM
Jan-20-2017 08:17 AM
Jan-20-2017 08:06 AM
Jan-20-2017 08:04 AM
Jan-20-2017 08:00 AM
wa8yxm wrote:
The full answer is rather complex but the short answer is YES. Been there, Done that in fact. (Well mine was 20 amp...)
By CODE, any "Modern" outdoor outlet is supposed to be protected by a GFCI. some RV's do not play nice with GFCI outlets. If this is the case it won't work, It will. however, be safe
You can charge batteries, "Chill out" the fridge (run it) but may not have enough power for air conditioners or water heaters.
Jan-20-2017 07:58 AM
86CoachmanR wrote:
I have an 1986 30A class A and am a full time RV'er and have been on campgrounds regularly but recently have been "Driveway mooching" with family.
My question is this, with the 30A male dogtail connected to a 30A female to 15A male adapter, can I safely plug into a 15A outlet with this setup?
I'm only looking to run a small LED LCD Monitor, a 120v Electric space heater PlayStation 4, Desktop computer, and the interior lights. Not all at the SE time of course. At most the monitor will be operating with either the computer on or the game system and maybe one lightbulb on.
I've had the motorhome plugged into aunt's house on a 15A garage circuit with the space heater, monitor, game system, and 1 light on at the same time for about 3 weeks. She is moving so I'm hopping over to another family members driveway. However they are concerned with running the 30A to 15A adapter plug through their circuit saying that it will cause a fire.
If I've done this at one house already, with no issues, no trips or anything, is it safe to say that I will not run into any issues here? By the way this scenario is running off of a split circuit board not the main one.
Thanks in advance, sorry for the lengthy post!
Jan-20-2017 07:53 AM
Jan-20-2017 07:47 AM
Jan-20-2017 07:42 AM
