Can't figure out how to grease u-joints - '93 Ford E350
rgnprof
I had new u-joints installed last summer on my Class C Ford E350 and I went to grease them and can't get to 3 out of the four (only one I coulod reach was the front). c I bought a new 'right angle' connector and still can't connect to the zerk fitting...
Is this an installation problem? Can't figure out why they would make serviceable u-joints with zerks that you can't reach and "service"...
Any thoughts?
12 REPLIES 12
Harvey51
I had a difficulty like that on the front wheel bearings. I fixed it by replacing the zerks with angled ones. Inexpensive and easy to do.
2004 E350 Adventurer (Canadian) 20 footer - Alberta, Canada
No TV + 100W solar = no generator needed
Dusty_R
It's been a long time, but I think that you can get a connector/grease gun fitting that is smaller, I don't think it locks on, you have to hold it on the zerk square and firm.
Dusty
rgnprof
I have tried the right angle - can't get it in between the yoke (the diameter of the connector itself is too large)...don't see how the needle will work either because I don't have a straight shot to the zerk. It's nuts! Either the shop who installed them paid no attention to the orientation during installation (and I'm not even sure there is an "orientation"), or ...I don't know.
theoldwizard1
Lincoln Lubrication 5803 Grease Needle Nozzle
The picture does not show it, but it should have a soft rubber tip.
How to Grease U Joints With A Needle Nozzle
enblethen
OP tried the swivel style coupler. Those are very large Zerk fitting end
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
bukhrn
shastagary wrote:
one of these may work Right Angle Grease Coupler
X2,https://www.google.com/search?q=needle+grease+gun+fitting&oq=needle+grease&aqs=chrome.5.0j69i57j0l4....
2007 Forester 2941DS
2014 Ford Focus
Zamboni, Long Haired Mini Dachshund
shastagary
amxpress
Try an adapter like this:
Grease gun tip
2021 Toyota Tundra TRD Off Road double cab
2022 Airstream International 27FB
Blue Ox Sway Pro hitch
M.I.L is self quatanting in Jacksonville Zoo
enblethen
These mini grease guns have a much smaller connector to the Zerk fittingsMini grease gun
Bud
USAF Retired
Pace Arrow
rgnprof
Spicer replacement U joints...Have tried rotating driveshaft, etc.
Was hoping for some recommendation for a new, really thin walled zerk connector fitting 🙂
Thanks!
Nv_Guy
Company that made U joints probably isn't the same as who made the driveline yokes.
As mentioned, you may need to rotate the driveline so there is some angle to the U joints, which will provide clearance to get the grease gun in.
enblethen
It could be simply a rotation problem. Block wheels a few inches, roll rig slightly to get fittings to an accessible locatiom
Bud
USAF Retired
Pace Arrow
